Drains only when cancel- reset pushed (manual drain). Suggestions?
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
SOURCE: Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
SOURCE: Bosh Dishwasher not filling
I had the same problem with no water coming in. Each model may be different, but i solved the problem by holding down the clean drain button for 5 seconds. On my model, it is two buttons simultaneously, then closed the door and waited for the washer to cycle through. Once completed, turn off and then back on again to run normal load. If this does not help. Call Bosch Directly. They have an excellent customer service desk (1-800-944-2904) or http://www.boschappliances.com/kitchen-appliances-dishwashers_dishwashers_Integra_800-series.html.
Hope this helps
SOURCE: My bosch dishwasher runs fine, cleans fine, drains
water inlet valve isn't closing all the way closed. Need a new one
Testimonial: "Thanks for your help. The inlet valve makes sense, I was just wondering if they are prone to getting jammed with gunk and can be repaired easily."
Hi
If clean light is blinking 7 times then it may be an issue
with heater circuit, door switch or wash pump. If yes then please reset the power
to the dishwasher. After, 5 minutes check if you are still getting the same
error. If yes, then it is a water heating fault. To resolve this error try
pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High
Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi
Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and
then you press the Cancel/Drain button and allow it to completely drain and
reset.
If this doesn't work then it's an issue with the wash pump not pumping the
water past the heater efficiently or due to lack of water to heat. Please make
sure that heater is not open circuited and is heating the water efficiently.
You'll have to check the heater using a multimeter; the meter should read
between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is
fine then make sure water pressure is optimum and fill valve is working
fine.
Hope this helps... Please post back if you need more
information.
Daniel
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
What I meant is that the cycle runs fine- dishes are clean and drains properly but at the end of the cycle instead of drying it simply cycles back to full cycle again. The only way to stop it is to depress the cancel /reset
