Question about Canon LaserCLASS Fax 710 Printer
Disable Printer Spool Option?
Laser Class 710 Fax--how can we disable the printer spool option to allow for Direct Sending all day without having to keep pressing the Direct TX button?
  • 71 Answers
To manually stop and restart the spooler service perform the following steps:
1. Click Start, click Run, type command, and then click OK.
2. Type net stop spooler, and then press the <Enter> key.
3. Type sc config spooler depend= RPCSS start= Auto, then and press
the <Enter> key.
NOTE: The spaces between = and RPCSS and = and Auto are important.
Without these spaces, the command will fail.
4. Type net start spooler, and then press the <Enter> key.
Posted on Jun 16, 2009
It will not print... I have reloaded the software,reinstalled the printer ,checked all of the drivers... It will receive and send a fax,however can't get it to print... The P/C does see the printer...
hi newprop1949,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
NOTE: DON'T DO THESE STEPS IF YOU HAVE ANOTHER PRINTER INSTALLED ON THE COMPUTER. JUST RESTART THE COMPUTER.
From the start search box type spool and press.
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just update me if the issue is not yet resolved.
Oct 19, 2009 | Dell 926 All-In-One InkJet Printer
Printer not printing
if your printer is giving you an error msg saying printer communication not available.
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
From the start search box type spool and press .
LexBce Server
Print Spooler
have a great day :)
Oct 01, 2009 | Dell 962 Photo All-In-One InkJet Printer
Scanner not working ... can't figure out why... need to scan my paycheck to deposit to bank but says scanner not connected (but it is) or not turned on (but it is) ... printer works fine, but scanner does...
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day. :)
Oct 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
I bought refilled catridges for my printer and it printed the test page fine. But will not print any documents from my files.All my connections are good and it even printed test pages from my computer what...
most of these issue are caused by either corrupt printer driver or busy print spooler.
have a great day :)
Sep 30, 2009 | Dell 924 All-in-One InkJet Printer
My printer is not printing everything else works, computer says that the printer is not connected.
hi there,
have a great day :)
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
Trying to print on my aio 926 printer but wont print i hook it up to my laptop and prints fine but not on my desktop
do you receive an error msg saying, printer communication not available?
if yes you can try these steps:
have a great day :)
Sep 26, 2009 | Dell Photo 964 All-In-One InkJet Printer
My Dell computer does not communicate with my printer
hi there,
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day.
you can check this link for complete info.
http://tinyurl.com/yddyuw6
Jan 30, 2009 | Dell 946 All-In-One InkJet Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Dell 926 printer wont print text.
do you receive and error msg like printer communication not available?
if you're receiving printer communication not available, you can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day
Dec 23, 2008 | Dell 926 All-In-One InkJet Printer
Printing
Disable printer spooling in the printer properties and enable direct print
May 14, 2008 | Sharp AR-BC320 All-In-One Led Printer
Canon LaserCLASS Fax 710 Printer Logo
188 people viewed this question
old marine
old marine
