Question about Samsung Sprint Sph M900 Android Qwerty 3.2mp Cam 3g Slider Cell Phone Clean Esn
3.2 MEGA android stuck in idle mode for no apparent reason
It's been stuck in idle position now for approx. 15+ hrs. doesn't respond to any button. won't power off..without battery removal. seems to respond when power on..begins to load, then freezes up, and continues to idle, and also vibrates a lot. this happens frequently, but never exceeds 5-10 min. now seems to be in a permanent stance.
SOURCE:
SOURCE: Samsung SGH-U700 Freeze
forgrt iy!
Posted on Apr 05, 2009
  • 337 Answers
SOURCE: the phone continually freezes and stays frozen, i
you may contact the service provider..........
Posted on Nov 11, 2010
vish4
  • 409 Answers
SOURCE: My Samsung Pixon screen freezes quite often &
The problem is a faulty contact from the touchscreen leading to the phone board. To be short: on the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screens face a little from the phone body exactly at the volume down button(using ur fingernail or something) and see if the touchscreen is responding in anyway. IF this is your case too...I suggest get a screw-driver and open the chassis, and trying to make the connection permanent, somehow.PS: you can send it back to warranty of a repair phone shop, only to force you to buy a new touchscreen and pay for the repairs, on a 99% working phone, with a faulty contact. The choice is yours:)
Good luck
Posted on Dec 21, 2010
MobiExpert
  • 132 Answers
SOURCE: touch screen has stopped responding on my phone -
Your mobile's software has been corrupt you need to flash repair your mobile's software. goto your nearest mobile service center and ask them for flash repairing. Please don't forget to rate my solution. Thank you for using fixya and i hope it will be helpful for you. don't forget to rate my solution.
Posted on Feb 03, 2011
jordan101gre
  • 6 Answers
SOURCE: Android phone pattern locked
You can Easily Reset your Gmail Password For your Account all you have to do is Type in your username at Gmail.com and If you select Forgot Password, you can reset it to Something you will Remember.
Posted on Jan 04, 2014
Testimonial: "Thank u so much, have reset my passowrd and my phone is working perfectly"
Hisense sero 7 is not chargeing what do i do
Android Tablet not charging
Reasons:-
1- Set stuck
2- Sleep of death
3- Due to Dust
4- Power button broken
5- Carbon
6- Dry Shouldering
7- Corrupt OS
8- Faulty Charger
9- Charging connector Damaged
Solution:-
Android Tablet Not Turning ON 15 Reasons Solution
Feb 19, 2015 | Tablets & eReaders
Power button stuck on tablet
Radio Shack has 8 air cleaner that also has a composite resolution in it that will unfreeze the buttonbe prepared to spend about 12 to 15 dollars for a 6 ounce can
Dec 31, 2014 | Irulu 7" Google Android 4.0 Capacitive...
My new cell phone plays a short little "tone song" about every 15-20 minutes when the phone is idle. I have checked and there are no new texts or e-mails coming into my phone. Needless to say I am not
Others report the same problem and no one knows why. Time to buy an iPhone. What you can do is put it on Airplane Mode overnight.
Phone lights up for no reason while on idle/standby - Samsung ...
https://androidforums.com > ... > Channels > Android Devices > Samsung Galaxy S3
Jul 15, 2012 - Simply put, what happens is that when I leave my phone idle, it would suddenly light up for no reason. It's similar to when the phone lights up when a... Missing: minutes
Tips & Tricks for Improving Battery Life - HTC Blog
blog.htc.com/2012/06/tips-n-tricks-for-improving-battery-life/ Jun 1, 2012 - This helps preserve batter life and also avoid interruptions when you're playing videos on your phone or when you leave it idle at night. When you're not jumping from one city to another, sync weather updates of only your current city, rather than in all of your named locations. In the Weather app, tap Menu ...
Google needs to solve Android's inconsistent idle drain. : Android ...
https://www.reddit.com/r/.../google_needs_to_solve_androids_inconsistent_idle/ Jan 10, 2016 - But it's incredibly frustrating sometimes, not knowing whether my phone or tablet is going to have a "good day" or a "bad day" for battery life due to no ...... Yeah, because there a few things developers can do on iOS to keep a task running in the background longer than the 15-20 minute restriction that ... Idle Battery Investigation -- Is Facebook a Battery Hog Still ...
17 Jul 2015
Why does my phone keep buzzing?!
22 Jul 2011
More results from www.reddit.com
cell phone plays notification every 15 20 minutes when phone is idle...
Jan 07, 2018 | Cell Phones
Volume doesn't work on bose radio in car all the time
Sue,
I had the same issue with a car I owned and had to replace the unit.
May 04, 2017 | 2009 Nissan Rogue
I cannot adjust the stations, switch to CD or Radio mode or anything as it's stuck on one XM station. The presets won't even change the station. I noticed the disp/title button seems to be sort of stuck...
Yes, Disp/Title stuck button could be cause of no other button function because one button can be operated at one time in these units and if any button stuck for some reason, other buttons would be inoperative.
Take off front panel by pressing eject button at lower left side and try to release Disp/Title button with finger nail, if that does not help then remove screws at back of front panel, take off back cover then take out circuit board carefully and press gently, little bit Disp/Title knob from inside front panel to send it back in its original position then put circuit board and put back cover and tight screws.
Check Disp/ Title button gives little click sound while pressing as other buttons give that sound. Put front panel in unit and check.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 13, 2010 | Alpine CDA-9820XM CD Player
My LG BL40 hangs quite often, when i try to delete...
I wont to delete web address from the browser of BL40 LG
May 16, 2010 | Cell Phones
Remote says OUT OF RANGE when i try to arm it.
Reprogram the remotes using this procedure:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
May 07, 2010 | Megatronix - TW71 - 5 Button 2 Way LCD...
My kids got a hold of my calculator. Now it won't
Apparently it's stuck in Exact mode. Press MODE then F2, move down to "Exact/Approx", press right-arrow, and choose the desired mode.
FYI: even when you get a fraction, you can convert it to decimal by pressing Diamond followed by ENTER.
Apr 30, 2010 | Texas Instruments TI-89 Calculator
Treo 650 freezing if idle for a few hrs
Maybe a button is getting stuck, or a component has stopped working.
Jan 01, 2010 | Palm Treo 650 Smartphone
STAND BY MODE
We had a similar thing (after using it for 4-5 years). After haveing it on for e few hours
some resistance or condensator or so gave a sound (bang) and it went back in the stand by mode. Now it really broke , while showing in the screen "F61" which means that there is something wrong with the eletricity supply. Well, we will start from there with an official repair man. Let you know what it takes to get it repaired. Frasha
Aug 08, 2007 | Panasonic SC-HT75 System
Samsung Sprint Sph M900 Android Qwerty 3.2mp Cam 3g Slider Cell Phone Clean Esn Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
