Question about Lucent Merlin Legend MLX-20L Phone
How to program night service
I thought i programmed it correctly but when i click the button to activate the phone is not on night service it still rings regularly.
  • Carl Navarro
    Carl Navarro May 11, 2010
    If you programmed it correctly, it isn't correct :-)Night service has a program and you have to program the RINGING. Just putting the system in nights tends to make it ring on purpose.
Did you program the lines to be answered, in the night service group?
Posted on Oct 17, 2009
654812-69D4-73D1 how can I activate the product ?
Instruction how to install and activate the game:
1. Follow this link - http://www.files.citycardriving.com/CityCarDriving_En.exe to download the game.
2. Run the downloaded installation file with administrator privileges (right click on it and choose "Run as administrator in the context menu) and follow instructions of the setup wizard. During the installation process you should agree on installing all additional software, because it's necessary for correct program operation.
Now you should obtain the program activation key:
3. After installation of the program is finished, run the installed game with administrator privileges (right click on the game's shortcut and choose "Run as administrator in the context menu).
4. Copy the product code from the game startup window.
5. Follow this link - http://www.activate.citycardriving.com/
6. On the web page you've just opened you should enter: your serial number, the product code you have just copied, and your e-mail.
The activation key will be displayed on the final page, after you'll click the "Activate" button.
7. Enter your activation key into the box in the game startup window and click "Registration" button.
Jun 14, 2014 | Computers & Internet
Norstar m7324 won't come off night ring
Is the button still programmed?
Do F871 in meantime....F#871 on older systems helps too or just F87.
Program button:
F*3
button
Feature
871
Jul 23, 2012 | NorStar M7324 Telephone
Hi there, I have a Euromaid WM5 and suspect it was overloaded as it stopped near the end of the cycle. We turned it off at the power as it wouldn't reset and couldn't get clothes out. It has been off...
I think, that if you want to cancel the program, you have to select correct program on selector knob. When turning the knob observe the display. When correct program is selected, it will show spin speed and temperature.
I have also managed to reset the machine by entering service mode. Turn it off, select Cotton program. While keeping Start/Cancel button pressed, turn it on. It showed E 05, then whole display started blinking. Using the same button it started spinning. After turning it off and on again, the machine was reseted.
Feb 21, 2011 | Washing Machines
I miss my office 2007 product key
take it
KGFVY-7733B-8WCK9-KTG64-BC7D8
enjoy :)
Feb 18, 2011 | Computers & Internet
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
I WANT TO INSTALL NORTON INTERNET SECURITY BUT I CAN'T FIND HOW TO ENTER THE PRODUCT KEY
1. Click the Start menu button, click "All Programs" in the pop-up menu and select "Norton Internet Security" to run the program.
2. Click the "Activate Now" button that appears at the bottom of the Norton Internet Security's program window, or click "Renew Now" if you're using pre-installed software. Click "Next" in the Norton Account window, and enter your full name, address, phone number and email address. Click "Next" to proceed with the activation.
3. Type in the Norton product key located on the software's product case or select your payment method, and enter your 16-digit credit card or debit card number. Enter your expiration date, and enter the security code located on the back of your credit or debit card.
4. Click "Next" and wait for the Norton Internet Security program to connect to the Symantec server. The program will send your billing and payment information to the Symantec server, and activate your program.
Sep 26, 2010 | Acer Computers & Internet
How to reset lg phones
http://www.lg-phones.org/lg-dare-master-reset.html
1 - Open the Flip
2 - Press MENU >> Then ' 0 ' [ zero ]
3 - At the Service Code prompt enter six zeros
4 - Choose option 12
Phone should REBOOT and RESET to Factory Defaults... But, if you want to go to the pre-activation stage, that's a different process...
1 - Flip Open, Press Menu
2 - Press 0 followed by 000000 [6 zeros at the Sevice Code Prompt ]
3 - Choose Option 1 [ Service Program ]
4 - Click the OK soft button [ brings you to the * Phone Number (MDN)* screen ]
5 - At that screen enter 10 zeros - to replace your current phone number
6 - Click the OK soft-button
7 - At this screen repeat step # 5
8 - Now click END
Phone will REBOOT by itself and the screen will now display " Initial programming Required " - This is what the Sales Rep sees when he/she opens the box and boots the phone the very first time to program it to your account
Aug 26, 2009 | LG Vu CU920 Cellular Phone
Initial Programming Needed on Samsung Renown with Verizon
Verizon customer service isn't always very helpful, but the verizon website can be. Try clicking phones&devices under the support section. Once you select what type of phone you have, you will see that it says "activate phone" on the left side of the page. This will guide you through the activation of your phone, and the instructions are pretty clear. Hope this helps.
May 21, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Avaya 4424LD Night mode
By pressing the night button. Is there a night button? Which system is it?
Mar 14, 2008 | Avaya Lands Phones
Lucent Merlin Legend MLX-20L Phone Logo
504 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
