Question about Windchaser PACR10 Portable Air Conditioner
Windchaser AC leaking water
The top part is holding water but not draining to the bottom water holder is there a clog??? Only 2 years old.
    Sergeant:
  • 340 Answers
Maybe cloged kinked line needs cleaning
Posted on Jun 17, 2009
Why my windchaser air conditioner keep leaking water
Eithee the filter is dirty, coil is dirty, primary pan is dirty or the tube or drain is clogged. It needs a good bath!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 25, 2017 | Windchaser Heating & Cooling
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
I have an SA12059 Windchaser portable a/c. After using it and rolling it around, the top condensate tank drips lots of water. I tried to drain the bottom tank via the hose, but the top tank doesn't seem...
There is not actually a top tank, just a drip tray with little drain holes that become easily clogged. After removing the rear cover of the unit and cleaning thoroughly, you can use a can of air (like the ones to dust pc's) wth the little straw attachment to try to clear te clogged drain holes in the tray below the evaporator. If your unit froze up condensate may have overflowed into the fan area. Let the unit defrost, and run it in fan mode for awhile to dry this moisture out.
Sep 01, 2013 | Windchaser PAC9 Air Conditioner
My portable windchaser airconditioner pacr9 sounds like theres some water in the top area and is blowing out some water from the front vent ? any reason why ?
This usually happens when the unit is dirty. The filter provided is pretty worthless and dirt and dust build up inside the unit badly. This causes the unit to operate inefficiently. Condensate builds up on the evaporator and freezes. When it defrosts water drains through the unit to the bottom, whats left is a muddy sludge and a clogged evaporator. The condinsate will then overflow into the fan area. Normally the condensate will be exhausted through the warm air vent in the back of the unit.
To fix this, you need to unplug the unit, then remove the entire back cover. Not just the small cover on the upper portion. Once removed you can then have access to the entire evaporater and condenser. Clean these thoroughly with a vacuum and toothbrush if necessary, Let the unit defrost if the evap was clogged with ice. Drain the unit thoroughly with the tube at the bottom of unit. I lay a thick towel on the floor and let it drain into the towel. Clean the fresh air intake area on the upper rear thoroughly, I used windex, then flushed with water, which ten drained to the bottom of the unit, and out onto my towel. Reassemble and run in fan mode for an hour, allowing the condensate that overflowed into the fan area to evaporate. You should be all set.
This maintenance procedure should be performed yearly or as necessary on these units.
Aug 14, 2013 | Windchaser PAC9 Air Conditioner
Ac leaks
If you are talking room a/c then the holes are water drain holes. The one on the bottom allows water to drip into a garden etc and the one at the back you can fit a hose to drain away
Jun 14, 2013 | Windchaser Wind Chaser Air Conditioner...
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
When i run the ac it leaks on the floor from the inside n i dont know what to do about this problem.
All portable or window ac units are mounted or standing with the back lower housing at a slope
so that the condensed water buildup from the evaporator can drain into a tray or thru a tube out
the back of the unit, depending on what kind of unit you have you may have to take it apart and
make sure the drain for the condensed water is not blocked. some times these units are not
installed correctly, they will not drain properly and standing water with time will turn to rust and
clog up the tube where it needs to flow from the ac unit. good luck!
Jul 31, 2011 | Windchaser PACR10000 Portable Air...
Started leaking water accumulated on bottom shelf in lower level. now top freezer takes 2 days to freeze ice, bottom freezer vent clogged.
The drain is clogged. When the drain clogs it can also clogs the airflow vents. Remove the back wall of the freezer to access the drain. Remove all the ice blocking the drain and the vents. Then use a trukey baser to force hot water down the drain until water flows freely. Then mix water with baken soda and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 27, 2010 | Kenmore Top Freezer Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Kenmore Top Mount Refrigerator - leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing
It freezes up for a few reasons. First the water is not running down fast enough. That is why the wire was added to add heat from the heater to the drain hole. The metal pan under the evaporator coil may not be lined up with the drain hole well enough and holding water there. If that looks ok the drain tube that runs down the inside back of the unit might be slightly restricted. Not much you can do about that. I would make sure that the aluminum wire goes in the hole about 2 inches and that the unit is tilted slightly back to help water flow.
Apr 18, 2008 | Refrigerators
Windchaser PACR10 Portable Air Conditioner Logo
489 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
