Soyo 19 inches tft lcd monitor model MT-nNI-DYLM1986:Its working for a few minutes and start to smell smoke.When i check on the pOwer board I fownd a shorted diode,this diode number read (pke10a and p3c6409).I dont find that number on any catalog or suplier,let mi now a replacement for thi part please if it is posible ,what problem is the reason for this diode be shorted.Thanks very much for your help. Eugenio: service tech.
  • 10,594 Answers
Replace that diode with EPG20 part number 871997985
It is available in Part Store.
Reason of damage could be over current flow in diode and you need to follow its supplied voltage section that might have some other part shorted there.
Thanks.
Posted on Jun 15, 2009
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
SOYO 19 TFT LCD Will not come on. Says "no input signal" Re-bot does not work. Everything is plugged in.
if the monitor has more than 1 source then make sure it is in the correct one. make sure the cable is fully inserted in the monitor and Pc. try another monitor to rule out a graphics card fault on the PC
Aug 02, 2010 | Soyo MT-NI-DYLM2058 Monitor
Computer 19" LCD Monitor with TFT 1280 x 1024 8ms DVI Connector Integrated Speakers - DYLM1967 ...: After a thunderstorm, my Soyo monitor would not tu...
If it uses AC adapter, then check the DC voltage at the DC plug to see if you get any voltage, if it use Direct power cord then it may have blown fuse inside the monitor, then you will need to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | Soyo TFT 19" LCD Monitor
My Soyo 19" widescreen monitor suddenly went all white. Powering off for a few hours does not help, it only glows white. Any suggestions?
It glows white because the LCD controller (part of the LCD panel) is not getting the 5vdc from the logic board or the LCD controller board has blown fuse due to short circuits, see what LCD controller looks like here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
First thing to look for is to see if the ribbon cables on both ends are in place and have clean contacts.
Mar 26, 2010 | Soyo 19" LCD Flat Panel Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Power
check power cable and change if needed.
Jan 22, 2009 | Soyo TFT 19" LCD Monitor
Weird characters on monitor, cannot log-in
Well, either the monitor is messed up and trying to display a message like "No Signal" or the monitor is set for a different language.
What happens when you press the menu button on the monitor? Change you make changes?
Nov 18, 2008 | Computers & Internet
Monitor no power
Check Internal Fuse on Power supply board
Dec 20, 2007 | Soyo DYLM1986 Monitor
Computers & Internet Logo
27 people viewed this question
Alun Cox
David Payne
David Payne
