Question about NEC NR 7900A (NR7900) CD-RW Burner
My NEC NR 7900A burner will not burn music cd's or photos
I have tried burning music cd's on the Window Media Player 11, but my computer dosen't recognize my burner. I have uninstalled the buner and tried re-installing the burner but still isn't working. When I trouble shoot the buner it tells me that it is working properly. Need to know why?
Re: My NEC NR 7900A burner will not burn music cd's or...
I try to burn music from my libery with but i get a massege that says i need to instole my cd burner can you help me with this
Posted on Nov 21, 2008
0 characters
3 Points
Will this burn dvd
No, it will only burn CD's. You need a DVD-RW/DVD-R burner.
Jan 24, 2011 | NEC NR 7900A (NR7900) CD-RW Burner
Rewriteable disc will not burn.
well try to burn the music using the nero software
Jan 06, 2010 | NEC ND-3500A DVD±RW Dual Layer Burner
CD-Rom drive missing
Go to this webpage and you will be able to solve the problem. Basicallly, you'll be resetting the registry to recognize your CD ROM again. Be SURE TO FOLLOW STEP BY STEP. Print the instructions first so that you don't lose your place.
Apr 09, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
Write to CD
This is common. It usually means the laser diode is too weak to burn the layer on the disc, or the lens has lost it's clarity. This means the optical pickup assembly requires replacement. Probably time to replace the drive.
Oct 25, 2008 | NEC NR 7900A (NR7900) CD-RW Burner
I have a NEC NR 7900A music burner that came with my dell
It Sounds like you need a CODEC, to DECode the movie, so that it will burn it. Try this: goto download the decrypter. Install it, and you should be able to burn most, if not all the newer DVD's.
Let me know if this does not work for you. If that happens, let me know what version of Windows you are using
Dec 20, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
Wont recognize burned disks
This does sound like a defective drive, most likely a laser / reader issue, because the refractive properties of the CDR is different from a "pressed" disk it looks like thia failed TOC seek issue, the head starts at the center of the disk and reads outwards, the click noise is most likeley the head reaching the terminus (the outer limit of the motorised movement), the drive then unable to find the TOC gives up and decides the disk is unreadable. if this drive is within the manufacturer's Warrantee period I would reccommend sending it back.
Apr 25, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
NEC NR 7900A (NR7900) CD-RW Burner Logo
367 people viewed this question
Top NEC CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Michael Thomas
Michael Thomas
Are you a NEC CD and DVD Burner Expert? Answer questions, earn points and help others
