Question about Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230
I am Replacing a pump motor and I'm not sure of the connections
I am Replacing a waterway executive Euro Pump 2 Speed 2hp 220-240V, 50Hz pump with an exact replacement, except the wiring is different!
On the old pump the electrical diagram shows four wires High Speed (Neutral), Low Speed (Neutral), High Speed (Phase) and Low Speed (phase).
The Low Speed (Phase) was not connected.
The colours connected were:
White - High Speed (Phase)
Red - High Speed (Neutral
Black - Low Speed (Neutral)
The new pump has connections for:
High Speed(Phase)
Neutral
Low Speed (Phase)
How should I connect it?
  • andy145 Jul 14, 2009
    Thanks for your help.
  • 20 Answers
High speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
    Habit-Forming:
  • 77 Answers
To be honest I'm struggling to understand your description of the wiring colours and without seeing the motor it's difficult to advise. I wouldn't want to give you advice and then you interpret it incorrectly as the consequences can be potentially fatal.
If you live anywhere near Lincolnshire please feel free to contact me and I'll be able to help you further.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections.
Common is always the white wire
High speed is normally red
Low speed is Black
Green wire is always green
Oct 02, 2015 | Waterway Pool & Spa
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Waterway pump four wires res white black green which is ground old pump1.5 hp had three connectors plus screw ground new pump has four connectors plus screw ground
make sure new one is wired for 120 volt then the black goes to the L1 the white to L2 then the green to ground or case make sure to change brown and white to accomidate 120 volts
May 17, 2014 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
Motor wont spin
bad start up capacitor or replace whole pump and motor
Sep 02, 2013 | Waterway Executive 56 Spa Pump 2hp 2" 2spd...
We have an older version waterway executive 48 pump with top outlet 75mm thread and front outlet 90mm thread we live in australia and need to replace it can you give me some help on wher we can purchase...
It sound like that's the 2.5" x 2" wet end.
Spa Parts Shop can help you, they also ship internationally.
You didn't mention a Horse Power. The motors HP is likely wrong listed so provide them with the amperage of your motor as well.
Oct 26, 2012 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge : My Executive 56 spa pump (1-l/2 years old) is leak...
Thank you for posting your question here on Fixya.com.
There is a seal in there that a local pump repair shop can fix for about $30 - $50 with parts and labor. Waterway pumps use a 1000 seal that is not a seal the homeowner is usually successful at replacing themselves.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 18, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Jul 05, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230 Logo
1,351 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Craig Butler
Craig Butler
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
