Question about Mtd Southwest No. 21a - 121r700 Gas Yd/Gdn Cultivator
My statsmen rototiller with briggs 5 hp motor runs fine and the drive wheels pull but the tines won't turn. what could be the problem?
  • 40 Answers
The worm gear or a gear is stripped if you tent to jam it up with rocks a lot it strips the gears
Posted on Jun 15, 2009
Cub Cadet RT 65 rototiller wheels aren't engaging
It's possible you have snapped the shear pin in the transmission shaft.
Jan 25, 2018 | Cub Cadet Garden
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Garden master tiller 5020d
Get behind the tiller as if you are ready to use it. Look down towards the tines. There's a protective cover. Remove it and you will see the belt running vertically between the motor and the tines.
May 08, 2013 | Ardisam 5.5 Hp Rear Tine Rototiller
Have a rototiller it moves OK but the tines do not turn It is a mtd yard machine rear tine
Seems to be a fairly common problem with these units. If the big pulley is turning which I assume it is as the drive wheels work, it is most likely a problem in the gear box. The shift mechanism in these units leave a lot to be desired. You can try to repair it your self or take it to a service center. Labor will be high due to the amount of time required to separate the engine and transmission.
Apr 18, 2010 | Mtd Products Yard Machines 158CC Tiller
Troybuilt rototiller
Most of them have a pin to lock the wheel to the axle... Check the center hub of the wheel and see if you can find some kind of hole that a pin would go in to lock axle to the wheel...
May 20, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Wheels turn, tines don't
These machines have an arm to activate the tines independantly from the wheels, make sure that the tine arm is in the on position.
If not, seems like you have a transmission problem, you'll have to get dirty to fix this one and open up the transmission casing to see if its just the link between the tine arm and tine crankshaft that broke or if its more serious.
Apr 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Rototiller will not start
paul i assuming you mean the motor stopped running,not the tiller part........? you say the motor turns over easy,suggesting that the motor hung a valve open and you have no compression in the motor.i'm hoping that you checked the oil level before you started and ran the engine. oil level is at the second thead down from the top of oil fill hole. if it was any lower the that you could have ran the motor low of oil causing one of the valves to stick. never had much luck on cleaning the valve stem or valve guide in the head,usualy you need to replace the head assy. they do come as a unit but they are pricey. take the valve cover off and see if both valves will push down into the cylinder. also see if one or the other valves are lower then the other. if you need more help i'll be glad to help you out as much as possible.......
Mar 11, 2009 | Husqvarna 26" Front Tine Tiller
Mtd Southwest No. 21a - 121r700 Gas Yd/Gdn Cultivator Logo
209 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
