Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
Motor seems to work fine, pull trigger and no water comes out
Plastic screen where water enters washer has melted
2 Suggested Answers
  • 958 Answers
SOURCE: Powermate pressure washer Model PW0872400
pressure washers has this pressure switches where in as you press on the trigger, the washer works and if you release it, the pressure would build up high and it would trip this switch to turn off the motor or deflect the water to the by pass hose ( if the motor is not stopping) then as you press again the trigger, water should come out of the gun again but would not,
i have encountered the problem is in the pressure switch, even the pressure went down, sometimes it wont close the contact then the motor wont run ,
if the motor is continously running, then the trigger switch is the problem, the pressure excerted on the switch is so high that even if you press it , it won't open up to release the water.
what i can suggest is to tie the trigger in the gun so that it is always pressed and then just unplug the unit if you want to stop using it. it is an inconvenience but it will work.
or, open the gun and see if you can figure out why pressing the trigger would not open the switch.
another option is you can lower the pressure of the washer if it has an adjustable pessure controller. by lowering the pressure might open the switch when ever you press the trigger.
i hopw i was able to fix...
good luck,
drcool
Posted on Aug 21, 2008
Little plastic parts behind the six big nuts on brass end of the pump have melted.
Hi
These are the valves If they are melted this is because the washer is being left running without being triggered. I also suspect yoru unloader may be failing...your will want your unloader tested. The only way to test anything is to replace these valves first. unfortunately I would also inspect your packings as well as the pistons. when water builds up for a length of time without triggering the washer it recycles and builds up heat....this heat starts to melt your valves....this can also happen by starving your pump for water....running it without water....or by a failed unloader where it doesnt allow water to bypass...do you have to pull the trigger of your wand to start it? If so then your unloader needs work. If it has been starved for water..then your packings will show that damage as well...Usually the farthest set from the inlet having the most damage. Also, when that all get hot as soon as you trigger it and cold water is introduced into the pump, this "shocks" the pump packings and pistons. You want to check the pistons to see if they have cracked..So inspect your pump oil for water...look to see if its white-ish looking... Check your pistons for cracks...check your packings for wear. If you see wear that increasingly gets worse the farther away from your pump inlet then thats a tell tale sign of starvation. ..if your pistons are cracked you will need to replace packings as well anyway. Then replace your valves...reassemble and test your unloader. Good luck to you man. You can get all parts here Pressure washer parts catalog quick links Pressure Washers High Pressure... or FIND PARTS FAST
Aug 12, 2014 | Comet Garden
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Will not pump out
check water pump for blockage or fault
Jan 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
No cold water to my Maytag Top loading washer
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
May 14, 2009 | Maytag PAV2300 Top Load Washer
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
Water on swich power on push down trigger no water then motor stops go's completely dead
the problem was in the gun, the nipple had broken off the plastic gromit,in the brass part of the trigger mechanism, stopping the water comeing out the wand and stopping the motor.
Apr 08, 2009 | Garden
Dishwasher not cleaning/water sprayers not spraying it appears
I had the same thing recently. Everything appeared fine mechanically, but no water would spray. I inspected the bottom arm as closely as possible and actually found a half melted clear plastic straw inside of it. 30 minutes, tweezers and a small pick eventually got it out and all is fine.
Sep 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Calypso Washer, seems unable to turn drum or agitate
I haven't had the problem with the washer tearing up my clothes as of yet but I have with the c1 error code. According the the manual there are three possibilities. 1- Bad drive motor 2- Bad thermal protector ( solution to fix replace the drive motor) 3- Bad motor control board. The last one was what needed to be replaced in mine.
Feb 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
64 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
