Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel Washer
Problem for Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel...
Hi my smartdrive machine keeps going off balance
By geoffandshir on Jun 15, 2009
hi my smartdrive machine keeps going off balance during the rinse an spin cycles, when you look in the machine when it empty the bowl doesnt seem to be in the centre ,is there anything that needs to be adjusted,hope you can help thanks
Solution #1
posted on Sep 07, 2009
Not Rated)
mothmanmeg
Rank: Guru
Rating: 85%, 59 votes
sure- hopefully you have a bit of room to move your appliance a bit. lay down on the floor, if able. use a flashlight. you should see 4 nylon or metal feet that the washer sits on. they'll have threaded bolts that lead into the bottom 4 corners of the washer. don't know how old your machine is, but if things look rusty, a little wd40 sprayed on them will help!
have someone help you lift the end of the washer opposite the way the axis of the drum is tilted. jiggle the drum a little and observe whether it becomes more centered. if you can, stick a piece of 2x4 , or 2x2 under that edge and turn the pads in a 'lefty-loosey' direction. this will raise one edge. take out the wood or spacer, and check the centering. you may need to mess with all 4 'feet', to get it right.
make sure your floor/platform the washer is on is solid!! if it's rotting out, check that your water connections are not leaking, and your drain hose is properly seated! good luck.
Was this helpful?
Yes
No
Solution #2
posted on Jul 21, 2009
Not Rated)
dustymirror
Rank: Wiz
Rating: 90%, 21 votes
sounds like your "bias spring" has broken or fell off. This is located at about the 7:00 position under the top and attaches the tub to the drum supports and keeps the tub aligned. It is possible that you have a bad tub support as well, but less likely.
Was this helpful?
Yes
No
Popular Solutions for Fisher and Paykel
Questions and Unsolved Problems for Fisher and Paykel
Do you recommend Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel Washer?
Answer
Answer
My Fisher and Paykel washing machine smart drive 608 won't switch on
Answer
Hi, I have a 601 model its about 14 yrs old, love it but now My hot and cold water are both... (More)
Answer
I have a fisher and paykel 601 smartdrive, it will not start, no lights come on, have spare parts... (More)
Answer
hi,i have 5.5 smartdrive 9 excellence washing machine,it was alright,until i was about to start the... (More)
Answer
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
