Question about Cell Phones
When i switch on my nokia n81 mobile phone i get as far as enter pin code but cannot enter code as none of the buttons work on the keypad. also phone keeps beeping when switched on.
    Sergeant:
  • 296 Answers
Hi
1-check flat and connector
2-change ic key z4400
3- change slide key camera
4- rehot omap ic
good luck
regards
Posted on Jun 15, 2009
  • Anjana Batabyal
    Anjana Batabyal Jun 16, 2009
    hi
    sorry for the inconvenience,i found another method to solve ur prob,plz try this..
    try reset like this, all data will be erased
    otherwise update rom from www.nokia.com
    else if not works then the strip between the keypad slider mechanism is damaged and needs replacement check ebay u will find it cheap
    pls first hard reset like this if it helps
    Master reset
    1)remove the ( memory card )and do formatting *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
    if it doesnt work then try this to hard reset
    switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds.
    1-if the main key pad 2 sol.1st try another ui(user interface )
    2nd the filter on the mb beside the key pad con.(z2400)the manual of n81
    2- then please check under the cover and under the do-mme sheet if there is any water or short if not change the main fpc and then the second step like before
    3-Please check if there is any stuck key
    For ROm upgrade
    downlaod the software update utility from nokia and then connect the internet and update ur ROM thru cable supplied with phone u will get all software for backup and drivers from the nokia website.
    hope i ve able to help u
    regards
Code error for Nokia 6600 "Lockj
UNLOCKING PHONE
Hi you can use codes to unlock the mobile . to get the unlock codes visit this link:http://www.unlocking4free.com/
Here they ask the following details before rendering the unlock codes they are 1. Mobile model 2. Country from where you brought the mobile 3. Provider to which the mobile is locked 4. Imei number of the mobile Finally they will send you the unlock codes at free of cost.once you entered the code in your mobile as for the instruction given by them .your mobile get unlocked and it accepts any network sim to get the IMEI: UnlockPhone Via IMEI. Your phones IMEI is your unique number that is given to eachphone. For each IMEI there is a unique unlock code that once entered into your phone will enable you to use any compatible sim card. You can get theIMEI for your phone by entering*#06# into your keypad. You will only need 1 unlock code to enable you to use any sim card in your phone and enable it to be "network sim free".
you can also try going to this site:http://www.foneszone.co.uk/unlock_codes/ though this site may not guarantee a free service..
or you may try one of this:
reformatting NOKIA Series phone:
simple ways to format your Nokia NSeries cell phones.
(Please do remember that some of the steps below will clean up all your data in phone so remember to make up backup copy of it. Otherwise you will end up loosing them forever.)
Method:1
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and '3? button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message 'Formatting' appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
2. Hold down *#7370# button.
Method: 3 Soft Reset
2. Hold down *#7780# button.
http://techalites.com/2008/05/06/how-to-format-nokia-n72-n73-n81-n95-nseries-phones/
please give time to: ---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Sep 08, 2011 | Nokia 6600
Tip
How to format Nokia N72, N73, N80, N81, N95, NSeries Phones
<span> <p>Nokia Became the Most Admired Mobile Phone Manufacturer and Most of the World mobile phone users have <a href="http://www.messiphone.com/mobile-secret/nokia.html">Nokia phones</a><br />But some models are more popular than others like N72, N73, N80, N81, <a href="http://www.messiphone.com/mobile-secret/nokia-n95.html">N95</a> and NSeries. <br />To fix some problems ( eg : get infected with virus, some system errors or installed too much software on it), many users asking me how to format Nokia NSeries Phone</b>.<br /> <p>So here are 3 ways method to format your Nokia NSeries cell phones<br /> <p><br /> <p><span> <p>Method 1<br /> <p>1. Turn off the mobile Phone.<br />2. Press and Hold the following three buttons: Green Call Answer button</b> + the "*" button</b> + number "3&prime; button</b>.<br />3. While holding these buttons, press the power button</b> and switch on the phone.</b><br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons</b>.<br /> <p>Method 2<br /> <p>1. Switch off your Noki</b>a mobile phone<br />2. Now Press following key sequence *#7370#</b><br />3. Enter Default lock code is 12345</b>.<br />4. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />5. Wait for message 'Formatting</b>' to appear on the screen and release all keys once you see that message.<br /> <p><span> <p>Method 3<br /> <p>1. Switch off</b> the phone.<br />2. Hold down *#7780#</b> button.<br />3. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons.<br /></span><br /></span><br /></span>
on Jan 11, 2011 | Nokia N73 Cellular Phone
Tip
Nokia formating tips
Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Nokia phone
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
on Mar 10, 2010 | Cell Phones
I forgot my nokia n81 security code. imei: 356994012762039 email : hendra_dd84@yahoo.co.id
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 30, 2010 | Nokia N81 Smartphone
How to format the nokia n81
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Sep 04, 2010 | Nokia N81 Smartphone
I forgot my security code i wnt to formai can you get me the formatting code
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone.
Jun 23, 2010 | Nokia 6300 Cellular Phone
How can me format my mobile telephone ? (Nokia N95 8GB)
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone
May 17, 2010 | Nokia N95 Cellular Phone
L forgot lock code
You will need to format the phone.
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting.
May 17, 2010 | Nokia N73 Cellular Phone
Nokia N 81 Camera: feature not supported
open your mobile then press on the keypad *#7370# it wil appear "restore phone to its original settings" press "yes" and enter your lock code if you dont have lock code enter "12345" and press "ok" it will work
Mar 29, 2009 | Nokia N81
Nokia n81 8G
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1:
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
2. Now Press following key-*#7370#
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Jun 02, 2008 | Nokia N81 Smartphone
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
