Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Light went off on refrierator side and control lights went off also
  • 40 Answers
Light bulb needs replacing have a whirlpool tech look at in
Posted on Jun 15, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
How do I fix the red light lock on a sub zero refrierator
If it's showing red all the time, it suggests it is not reaching temperature.
May 03, 2012 | Freezers
The temp. indicator went off on our side by side whirlpool fridge. The fridge is still running cold, but there's no light in it. I thought it was the bulb, but i tested and it was fine. Any suggestions...
only light i could find is the filter light . and the main light 40 w appl globe the control does not use a light . the main light reflects in the control panel to give back light . the filter light is for filter only . and is out if filter is ok .. .hope this helps mm
Jan 20, 2011 | Whirlpool GC5SHEXNS Side by Side...
Light in refrierator does not go out when you close the door.
Check the door switch is operational by pressing it with your hand. When you press it, it should turn off the light. If it does that, then check the door if the door braket is worn or loose or is not hitting the door switch when closing.
Aug 16, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
Light in refrierator won't work
If the light still didn't work and you are sure the bulb is good, then the next thing in line to check is the door switch. Off the top of my head, I'm not sure where the door switch is on this model, but the switches are usually at the bottom. Door switches are notorious for getting sticky. Lots of things get spilled in the fridge and run down to the switch. If the switch doesn't pop out when the door is opened, the light won't come on. Usually just working the switch and cleaning any sticky stuff from it fixes the problem. If not and you have a meter, you can check the switch. If it checks bad with a meter, then it has to be replaced.
Hope this helped
Jul 23, 2010 | Kenmore 57029 Side by Side Refrigerator
Fregerator not cooling
check out the refrierator defrost sensor for the refrigerator side. the connection may not be making a good contact. open up the refrigerator evap section and behind the lights for the crisper is the connections. be carefull because the evap may be frozen up and the styrofoam wil break if its frozen up. thaw it out first with a shop vac blowing air out.
Mar 06, 2009 | Samsung RS2534 Side by Side Refrigerator
Fridge making "knocking" noise
Remove the light shield and there should be screws under it. Remove the air tower in the back, it snaps in and there is 2 screws behind that as well to remove the damper housing that sits behind the light. Also not sure what your model is but some models have 2 air ducts that run up each side, they come out after the light shield is removed by sliding foward and then pulling down. After the screws are removed in the upper plate the light assy will snap out and there is 2 quick disconnects on the wires.
Jul 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator will not cool
also the complete mod number would help
May 21, 2008 | Refrigerators
Do you mean the display won't go below 70 or that the actual temps won't go below 70? First try to unplug the refer for 20-30 seconds then plug it back in. Hopefully that will reset the levels to factory settings (usually around 0 for freezer and 36 for refer).
Dec 18, 2006 | Kenmore 73503 Stainless Steel Bottom...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
