Question about Maytag Atlantis MAV6000 Top Load Washer
My top load maytag leaks from the bottom during wash cycle
What is the problem and is it worth the repair
  • 87 Answers
90% chance it's just a loose hose or a bad fitting/clamp. Very cheap and easy to fix. If you like your washer, I'd say either pay to have someone come repair it, or if you are handy (or have a handy friend) give it a try yourself. You'll have to remove the back and find the leak.
Posted on Jun 15, 2009
My Maytag bravo is leaking out of the rear left side, any ideas?
I think I'd be checking the dispenser in the left rear for a crack or rub mark. Also the hoses going to and from the dispenser. They are plastic and fragile.if the top has been lifted or an extremely
off balance load ,one may be damaged.
Jan 18, 2015 | Maytag Bravos MTW6600T Top Load Washer
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Leaking from the bottom during the spin cycle
i would check the drain hose as well as any gaskets/seals for malfuctioning
Nov 06, 2009 | Maytag PAV2300 Top Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Maytag front load leaking at drum spider
Probably not. Sounds like bearings and seal is shot.
Sep 08, 2017 | Washing Machines
Water leaking
If the water is leaking at what seems like the beginning of the spin cycle it might be the hose connection to the drain pump or the pump itself. If so, it's a lot easier to fix than the drum seal.
Dec 31, 2007 | Maytag SAV5701A Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
132 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
