Question about Thomson 21DC320 21" TV
  • KentMan Jan 30, 2008
    Same thing, the solution hasn't helped, does anyone know of any other ways?
  • shakeste Aug 14, 2008
    I have thompson Cinema(21"), i get a M letter at the bottom left corner, and the volume now changes by 4 units, for e.g i can only change volume from 16 to 20 but not to 17, kindly assist.
When the TV is in stand by mode, press both volume controls on the TV and the blue botton on remote control for 5-8 seconds. All buttons must be pressed at the same time.
Then the P will disappear.
Good luck
Best regards
Posted on Nov 16, 2007
Posted on Jul 18, 2008
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press each dot to recalibrate the screen.
Once completed the Nuvi will display Calibration Complete
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
I need help to install this program
Hello Cryspycritte, Thank you for the clarification. Your program is definitely compatible with Windows XP. What you will need to do is put Disc 1 of Print Workshop into your CD drive. Click on your start button in the lower left hand corner of your desktop, then click run (located right above the "turn off computer" button.) A run box will appear in the bottom left hand corner. In the box type: D:\setup.exe (where D is the letter of your cdrom.) A setup window will appear with the final steps for installation. If you have any installation issues please post a reply. Thanks for using FixYa! Edward
Aug 24, 2010 | ValuSoft Print Workshop 2003 for PC
I need to change the wireless channel on my Thomson TG585 V7 and I have no idea how to do this! HELP I'm a complete novice. It is because my DSi is having problems communicating with the router. I have...
If this window does not appear browse to http://dsldevice.lan or the IP address of your Thomson Gateway (by default: and click Thomson Gateway on the menu on the left-hand side.
Change the wireless channel
Proceed as follows:
1 Browse to the Thomson Gateway Web Interface.
2 On the left menu, click Home Network.
3 Under Wireless, click your access point.
4 The Wireless Access Point page appears.
5 In the Location bar, click Configure.
6 Under Configuration, select the channel of your choice in the Channel Selection list.
7 Click Apply.
Helps that helps!
Jan 15, 2010 | Computers & Internet
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
Problem with letter stick on screen
Hold 2 volume controls down together until the P goes
Sep 01, 2008 | Thomson 24WK25U 24" TV
Two green lines on bottom left corner
Sounds like a convergance issue. I would have a tech set the convergance for you if you have not done it before, it can be tricky and you could make worse.
May 11, 2008 | Toshiba 65HM167 65" Projection Television
Audiosonic TV - Word "Factory" appears on top left corner
Try pressing the RETURN button (above the DISP button - number 6 on the button list in the manual). The button has two arrows chasing each other. It worked for me on our Audiosonic KMC TH68 TV.
Apr 02, 2008 | Televison & Video
turned the tv on ... blue screen ... red lock in left hand corner
Mar 28, 2008 | Thomson 24WK25U 24" TV
Thomson 21DC320 21" TV Logo
530 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
