Question about GE GSL25JFPBS Side by Side Refrigerator
Ice maker works, dispenser does not..water works fine
I just paid a guy to walk in, push the ice dispenser button, and then say," you need a new main board. They go out in this model all the time" Between $180 - $200 just for the part, labor not included. Found one online for $93....probably worth trying to do yourself???
  • GE Master
  • 4,655 Answers
Yes, Just make sure you have the plug out of the wall! Sea Breeze
Posted on Jun 16, 2009
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Apr 01, 2009 | GE PSS26SGR Stainless Steel Side by Side...
The icemaker in the door of our Kenmore Elite Trio frig just stopped working, exactly 13 mos. after we bought it. We did not get an extended warrantee, because we have never had a new appliance fail so...
Is the ice unit turned on? I pushed the off button by mistake and PAID someone to "turn it back on for me" The guy laughed all the way to the bank :( Also he said a good place to start , before I call next time, is have you checked to see if there is a ice cube frozen(caught) in the top.Pull out the ice catcher(bin) and check for the frozen cube of ice. Be sure to turn off the ice maker first or it may drop ice when you least expect it! My fridge is the origional for house (18 yrs) and after I've done this check list, the problem is fixed. Just thought I mention it. Good luck!!!
Mar 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
209 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
