My Triton finally will not turn on. It works just fine when it does, but as of the last year it started failing to boot up on the initial time I tried to turn it on. It did not seem like a big deal because it would usually turn on right after when I tried again. Then sometimes it would take two tries. You know where this is going... A year later, it finally will not come on. The screen flickers on for a moment if you "tap" the area on the face of the keyboard above the A/C port. Power chord works on other devices and I'm positive the wall outlet works. There was not one problem when it ran, but now it has gone dark. Any suggestions?
SOURCE: Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
SOURCE: Right front channel sometimes does not work
you have dry solder joints in the output stages to the front channel.-solution. resolder channel.... or dirty speaker protection relay contacts. can be determined by tapping the top of the protection very gently when fault occurring. solution. burnish contacts and treat with crc2-26
SOURCE: 37in Proton
Those are the symptoms when the power supply is giving up.
Unfortunately there are not many replacement service parts around to swap the power supply assembly, but It will need to be fix to the component level instead.
I service these power supplies.
Let me know if you need more assistance.
SOURCE: Korg Triton Le keyboard not working
Hello! My Triton LE did that yesterday at rehearsal room. It came on twice (by turning it off and on every time the error message appeared), I could play the auditions and demos but when i hit the keys i heard nothing.
Soon after I went home (still with sweat on my forehead and my heart pumping like a pneumatic drill) I connected it and everything was working like nothing ever happened!
So guys, everybody who has the same problem: Don´t panic! I think for me, the power plug at the rehearsal room had a problem. Who thinks of that? Nobody... So check your keyboard on another power plug...If you can, try it in a friends house. Or check your house plugs.
I assume if the Keyboard doesn´t get enough power, the error message appears. Hope that Helps!
SOURCE: goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
