Question about Brother SX-4000 Typewriter
I need to know how the correction tape goes onto the ribbon correctly
  • Brother Master
  • 3,594 Answers
The full spool goes on the L.with the tines to the right. the L/O tape goes thru the black guide with the dull side facing the paper. between the the shinny pieces, thru the black guide on the right around the slacker wire and the take up spool last.
If you have a fax # I can send you a picture.
DickyO
Posted on Jun 22, 2009
3 Suggested Answers
  • 3594 Answers
SOURCE: Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
Posted on May 20, 2008
  • 3 Answers
SOURCE: Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Posted on Oct 01, 2008
The correction tape is not woring
Take ribbon out type a small amount of charaters then do a correction and see if the wheel goes around, if it does motor is Ok the it could be a bad ribbon cassette.
Apr 09, 2014 | IBM Wheelwriter 30 Typewriter
How do i change the correction tape
tHE CORRECTION TAPE CARTRIDGE JUST CLIPS ONTO THE BOTTOM OF THE RIBBON CARTRIDGE. THERE IS A CATCH/RELEASE LEVER ON THE FRONT OF THE RIBBON CARTRIDGE.
Sep 06, 2012 | IBM Lexmark 6781-024 Wheelwriter 1000...
Remove the ribbon the correction tape snaps onto the bottom of the ribbon the latch is in the center.
DickyO
Sep 06, 2012 | Lexmark Wheelwriter 1000 Typewriter
How do you put in the correction tape in the brother A X--425
The correction tape feeds the same direction as the ribbon, andI think it only goes on 1 way. The tape goes in front of the ribbon.
Jan 25, 2011 | Brother ® Starter Kit for AX, GX, SX and...
How to change the correction tape
There are two levers on the right side of the carrier for the typewriter and correction ribbon. The little red lever close to the front right corner is to release the typing ribbon. the larger grey lever on the right end of the ribbon mounting bracket releases the correction tape. Pull it to the front, and it will release the correction tape. Look welll to see how the ribbon is threaded through the spindles and behind the guides next to the platten roller, before you take the old correction roll off.
NOTE: When changing either typing or correction ribbon, you need to know that only one of the levers mentioned will release at a time. If you have released one, you will have to snap it back into working position and pull the other lever to release it. THEY absolutely will not both release at the same time.
Feb 11, 2010 | Nakajima AE-830 Typewriter
PUT THE CORRECTION TAPE ON CORRECTLY
First, remove the ribbon. Now look at the left side of the printhead. (thats the unit that moves back and forth) You will notice that, above the spindel that you put the correction tape on, and towards the platen, on the black plastic, there is a recessed flat place about the width of the correction tape with slight serrations in it. This is the guide for the corr. tape. There is one like this on the right side also.
Put the corr. tape on the spindle, keeping slight tension on the tape, give it a 1/2 turn so the underside (dull) side is facing to the left, and put it in the guide. Then you put the tape behind the two metal "fingers" that are sticking up in front of the printwheel, and then into the guide on the right side. Then put the other corr. tape spool on the post on the right side, and turn it until the red "leader" on the tape is past the middle of the printwheel. The dull side of the corr. tape is the side that does the corrections, so make sure that side is facing towards the platen. Make sure the ribbon goes behind the metal fingers also. The tape and the ribbon should both be between the fingers and the metal cardholder.
Oct 17, 2008 | Brother SX-4000 Typewriter
Installing correction tape
This tape comrs in two small cassettes the full one loads on the L. side of the printer the tape goes across lower than the ribbon and wraps on the R. cassette.
DickyO
Aug 28, 2008 | Office Equipment & Supplies
Ribbons:
Nylon - MODEL 1032
Correction tape:
Aug 22, 2008 | Brother SX-4000 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Aug 12, 2008 | Brother ML-100 Typewriter
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Brother SX-4000 Typewriter Logo
193 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
