Question about HP w1907 LCD Monitor
Cannot get sound using dvi cable - HP w1907 LCD Monitor
  • 1,271 Answers
Check out these postings: http://www.lashen.com/vendors/calrad/hdmi_dvi.asp http://www.techspot.com/vb/topic11460.html if the connection is a simple crossover from vga to DVi , there won't be any audio. Regards GeWiz. 29 pin DVI Connector PinOut and Signal Names Pin # Signal Name Pin # Signal Name Pin # Signal Name 1 TMDS Data2- 9 TMDS Data1- 17 TMDS Data0- 2 TMDS Data2+ 10 TMDS Data1+ 18 TMDSData0+ 3 TMDS Data2/4 Shield 11 TMDS Data1/3 Shield 19 TMDS Data0/5 Shield 4 TMDS Data4- 12 TMDS Data3- 20 TMDS Data5- 5 TMDS Data4+ 13 TMDS Data3+ 21 TMDS Data5+ 6 DDC Clock [SCL] 14 +5 V Power 22 TMDS Clock Shield 7 DDC Data [SDA] 15 Ground (for +5 V) 23 TMDS Clock + 8 Analog vertical sync 16 Hot Plug Detect 24 TMDS Clock - C1 Analog Red -- -- -- -- C2 Analog Green -- -- -- -- C3 Analog Blue -- -- -- -- C4 Analog Horizontal Sync -- -- -- -- C5 Analog GND Return: (analog R, G, B) -- -- -- --
Posted on Jun 15, 2009
  • 253 Answers
DVI is digital VIDEO interface, you will need a seperate cable for audio
My ?LEVIA TV is connected to DirecTV cable box the TV has a great picture it is in DVI MODE but we Get No Sound can you please help me
DVI connection doesn't do sound... If your TV only has DVI, you need to run audio separately from the cable box. (DVI stands for Digital Video Interface. No sound part to it.)
Likely better to use a different interface.
Nov 28, 2015 | Televison & Video
I am down my mom house She gas a ?levia Tv I connected it to a DirecTV cable box to get a picture it is in DVI MODE Picture is very good BUT no Sound can you please help us
DVI interface doesn't carry audio like HDMI does. If you are using a DVI interface cable, you need to use additional audio cables to get sound.
Nec MT1060 blue screen when connected to a Hdmi source thru dvi port.Dvi setting to match Hdmi resolution.tried different cables and dvi to Hdmi adapters....any ideas..??
Hi Genaro,
Sounds like an issue with the HDMI HDCP content protection. I do not think it will be possible to connect using a DVI to HDMI cable.
Jan 19, 2014 | NEC MT1060 Multimedia Projector
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
Jan 08, 2014 | Hyundai Televison & Video
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
No DVI video output from dell xps 210
It sounds like your video card has gone out. Is the VGA and DVI ports on the same video card? If so the card is probably bad.
Mar 25, 2012 | Dell XPS 210 PC Desktop
I use attached the pc on tv but i didi not here any sound please tell me sound pin cable attached the tv?
Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
Mar 22, 2011 | Samsung HLP6163W 61" Rear Projection...
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
Acer H213H No sound
Dude, the hdmi is just for the video signal, you'll have to use a separate audio cable to get sound from the integrated speakers.
Jan 02, 2009 | Computers & Internet
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
HP w1907 LCD Monitor Logo
213 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
