Question about Ovens
Fridgidaire Gas Oven. Good for gassing the house, not baking
I see the element glowing orange, but no heat. With all the gas coming out unburned, I am sure that the element IS turning on the safety valve, releasing the gas.. This is after a couple of years of wondering if the thermostat was working right. I'm pretty handy, is this something I can fix myself?
  • 530 Answers
I would say you have a bad ignitor. it has to get so hot before it will ignite the gas. so if it is not lighting properly this could be your problem. check and make sure the flum tube has no blemishes in it or clogs.
Posted on Jun 16, 2009
  • erica graber Jun 16, 2009
    does the gas explode inside the oven. if so i would more say that you have a bad flume tube.
Why is oven not getting hot enough /not cooking from the bottom
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Jan 01, 2017 | Ovens
The top oven is not heating. I think that I need a baking element. It looks loke the model # is 966 40LX (or something close to that). When I search this model #, I come up empty. It could be that this...
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Mar 19, 2015 | Ovens
Frigidaire es300 bake element
The bake element
Apr 20, 2014 | Frigidaire Ovens
Inginator lightrs but oven does not heat
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
Feb 27, 2014 | Frigidaire FEB27S5A Electric Single Oven
MER5875QCS
sounds like when you put it on bake only the broil element is coming on,when in bake both elements come on,set it to bake,does the bake element glow orange when it heats up,if not the element could be bad and the heat is coming from the broil element or you could be only getting 120 volts to the element,so start it and see if the element glows orange or after like 5 minutes touch the element with a wet paper towel and see if it's even getting hot at all,if not make sure you unplug it or flip the breaker before you go to remove the element,there's 240 volts going to it and power is there all the time,i've seen people try to take it out with the power on thinking that the oven isn't on and POP not only is the element bad but they took out the relay in the clock assy. to by doing that.if you want to write back and let me know what you find i'd be happy to help you if you need more help.
Feb 07, 2018 | Ovens
My oven will not heat up. the orange light turns on but thats all.
I am assuming this is an electric oven? If you have an ohm meter you can verify that the bake or broil element is good by measuring the resistance across the element. If it reads short then the elements are bad. The more expensive problem which usually tends to be the case is the oven controller board. There are to relays that control the high voltage current that is supplied to the elements. When the oven is turned on a signal from the oven controller activates the coil on the relay and closes the contact allowing current to flow to the element. There are two relays, one for broil and the other for bake. Try the oven on broil to see if that element heats up. If it does it could be the bake element, if it doesn't you till need to get a replacement oven controller board. They usually call them timer modules or clock modules. Good luck!
Jul 20, 2011 | Kenmore Ovens
I have a Kenmore Gas Wall Oven Model Number 911.30469894. When BAKE is selected, temperature shows 100 degrees and the oven never starts up or gets hot. BROIL works fine. Thank you, John
The oven control supplies voltage to the oven igniter/gas valve circuit. When the oven control is set to Bake, voltage is supplied to the oven igniter which should glow bright red to almost white hot. Once the igniter comes on and begins to glow it must pull enough current to cause the gas valve to open so the burner can ignite from the igniter. I added an image below with the theory of operation. Click this link:--http://media.fotki.com/1_p,swbbsqrsgstsqkkxgtqsskgwtqkq,vi/wrgtsbrktxwdfwfbgdg/1/1303472/5961857/image5576034710104836299img-or.png
----Open the broiler drawer and then set the oven control to bake and watch to see if the glow bar igniter glows or not. If it does not glow, the failure could be a broken Igniter, failed oven control board or gas valve. If the igniter is glowing red, then it can be possible that gas valve is faulty. To see how igniter looks. See the fig below:--
To order this part click the link below:--
http://www.repairclinic.com/PartDetail/Hot-Surface-Glow-Bar-Igniter/1990?modelNumber=911.30469894
Also to confirm, check to see if the igniter is getting 120 volts when it's turned on. If it gets 120 volts, then your safety gas valve is bad because it's not letting the neutral go through. Otherwise, if it's NOT getting 120 volts, your control board shorted out and you need a new control board.
But as you mentioned that control board is replaced. So igniter should get 120 volts. If valve is faulty. But if igniter is not glowing then its faulty igniter confirmed.
To see how gas valve looks, please click the link below:---
http://www.repairclinic.com/PartDetail/Gas-Safety-Valve-Assembly/251898
In most of the cases the igniter is faulty, because gas valve getting faulty is very rare. But still getting the voltages checked, will confirm. These will help. Thanks. Helpmech.
Feb 04, 2011 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
Oven will not work but broil will work
If this is a gas oven the most likely part to fail would be the bake igintor,
If you look side when you turn it on you should see it glowing orange near the burner.
If you have an electric oven the most common part would be the bake element. There are two separate elements for cooking, one bake and one for broil
May 23, 2010 | Frigidaire Ovens
Igniter comes on but gas won't light
It should glow almost a bright white. If its just an orange glow then replace the ignitor. Its probably just weak. If its weak it will not allow enough current to flow through it to open the gas valve. Good luck _MJ_
Mar 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
61 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
