Question about Canon PowerShot A95 Digital Camera
I have a canon A95. Because of CF card forced to place wrong way, it bent the pins.. is there any way to open it and fix the bent pins
  • Canon Master
  • 4,738 Answers
Actually, it's quite simple, but does take some patience. Please see the following:
http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Posted on Jun 15, 2009
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Canon A95 PowerShot. Camear says no cf card, thought ok a card problem. Changed card, still same message. Help Please
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Jul 20, 2010 | Canon Cameras
Is there something wrong with the camera when it states cf err
you could have a bad CF card or it may need formatted .. or you could have a bent pin in the CF connector in your camera .. that happens a lot if the CF card is put in wrong or if its poorly designed (not much lead in taper to capture pins) ... look in the card slot where you plug in your CF card .. look to see if any pins are missing or bent ..
Oct 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error message 99
ouch ...look inside the camera where the CF plugs in .. you may have a bent pin ... some CF cards have a nice lead in taper so it centers the pins as you plug it in .. but some have hardly any taper (no idea why they make some this way) .. if the pin is off just a little with such cards then it bends the pin ... you might see a mark on the CF connector where the pin hit ... also if the card is forced in backwards or out of position you can bend pins ... i have one really nice camera that has 12 missing or bent pins .. someone tried to plug in an adapter that was poorly made (over and over) backwards and forwards .. that camera is spare parts now ..
Sep 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My Canon 5D card slot has a bent pin as someone forced a cf card in the wrong wayhow can I fix it ?
If you try to fix it, you will only bend the adjacent pins. Let a service tech do it.
Sep 08, 2009 | Canon EOS-5D Digital Camera
Memory card error for my canon powershot a95 keeps showing up.
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
May 05, 2009 | Canon PowerShot A95 Digital Camera
CF Card Err
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins?
You maybe able to fix it with pincers and a needle just align the pin or pins that are out of place, i did this and it worked for me and now my camera is working fine. and for free.
Good luck
Mattias
Oct 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon powershot a95
Think you may have bent a card pin. Remove the card and the camera's batteries. Look in the card slot for any bent pins. If you see one, don't fret, it may be fixable. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible (one from the dollar store is fine for this). Take your time and use as much patience as you can muster. Take a breather in between if needed.
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If there are no bent pins in the slot, then the next obvious thing to try is a different CF card.
Oct 12, 2008 | Canon PowerShot A95 Digital Camera
CF Card Error
Sounds like it might be a bent pin. Remove the CF card and look down inside the card slot for any bent pins. If you discover some, then also remove the camera's batteries. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
Jun 23, 2008 | Canon PowerShot A95 Digital Camera
CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Sep 14, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot A95 Digital Camera Logo
127 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
