Question about Canon PIXMA iP8500 InkJet Photo Printer
Too much green
Same problem. color looks correct when printed under the plain paper setting. It's green when I use any other "photo" paper setting
  • 33 Answers
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Thanks
Thiru
Posted on Jun 15, 2009
When I put my paper setting on any other setting other than plain paper , my photos has a green tone , why
If I had to guess, I would say that you are using non-HP paper.
If you are making this paper adjustment in photoshop, DON'T...
Make the adjustment at the time of printing in the printer driver itself under paper and quality.
Jul 11, 2011 | Designjet Black Designjet 30/130 Series...
I have an hp photosmart 7960 The problem that I have that I need advice on is that when printing on photo paper the photo comes out green When printing on plain paper the photo comes out O K in its...
You need to set the paper type in the printer settings before printing
start -> control panel -> printers -> right click on your priter and select properties. there you will find the settings, look around there is a page on paper settings.
try changeing those and print again. (select photo paper)
May 01, 2008 | Office Equipment & Supplies
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
The printer prints fine on plain paper, but on
I'm not clear on your problem but you can try this<a href="http://www.richardsnotes.org/archives/2006/05/17/canon-i9900-printer-problem-and-solution/" >Link for simular problems.</a> You may find the solution there.
Nov 27, 2009 | Canon i9900 InkJet Photo Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
When I print pictures from my digital camera the pictures are coming out with streaky lines as well as some off color in spots
Double Check Weather Or Not ALL Of The Packaging Tape Is Off The Ink Carts. Sometimes WE Over Look The Lil Tape Sometimes Blue, Green, OR Black. Make Sure Your Settings Are Accurate, As Far As Quality Of Print (normal-to-best). Check And See If You Paper Type Is Correct (Photo, Plain, Postcard...Etc. Only Thing That I Can Think Of? Hope It Helps!!!
Jun 04, 2009 | Epson Stylus Photo 1400 Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Cannot clean Canon i960
The print driver might not be sending the correct color profile for photo paper. Check that your selection of the paper type "sticks", that is, that it doesn't revert to plain paper when you click on the print button.
If the print dialog is not working properly, then please get in touch with Canon's tech support to resolve this.
Jul 26, 2008 | Canon I960 InkJet Photo Printer
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Canon PIXMA iP8500 InkJet Photo Printer Logo
136 people viewed this question
old marine
old marine
