Trying to instal new speaker
SOURCE: need instalation manual
http://www.directeddealers.com/manuals/OG/Viper/G3901V_09-2007_web.pdf
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
SOURCE: I have a jeep with a viper 5900 installed when
small box under or around steering column. may have to remove panel under steering column or get lucky and may find it if you lay on your back on floor of driver area. look up underneath for a box 2" x 2" x 1" black box with an l.e.d. light on it. arm the vehicle and bang on steering wheel and look for the led light to light up and set off alarm. light will be red or green and will only light up during vibration.
find adjustment screw on it and turn counterclockwise.
SOURCE: had this viper alarm installed on a mustang and
If your alarm is going off every 30 minutes its because a zone is backfeeding after the cars computer shuts down. First you have to find out what is back feeding... I would first disconnect the door trigger wire from the alarm to the car. Test it and if this is the problem then you should go to the latch wires of the car doors and not the interior domelight. If the problem is still there than you should check to see if the trunk trigger is the problem. Most techs pick up the trunk trigger in the trunk at the light. if you find that this is the problem then just remove the trigger from the light and add a pinswitch in the trunk.
