Question about Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cybershot S40 has white screen.still sounds like picture is being taken, reviewed, etc...is there anything I can do thanks
This sounds incredibly stupid but it instantly works- I had this problem with both of my daughter's camera (same model number)
On the front of the camera, to the right of the lense and under the flash, it says "Cyber-shot". Press that spot really hard/punch it. The LCD should return instantly.
Posted on Jun 23, 2009
    Scholar:
  • 89 Answers
Please check whether the battery is fully charged.
Please try using a different battery.
If the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is recommended.
Posted on Jun 17, 2009
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Hi, I have a sony cybershot, 5.0 and I cannot change modes from review to take additional pictures, what should I do?
Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Nov 25, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
DCS-S40 White LCD screen whats up?
i posted a pic i edited.
this is a hardware issue that really has no perm fix. but is easily fixable with my pic.
Oct 01, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot dsc-s40 lcd screen is all white
okay the lcd being white means its replacment of lcd time and not the camersa itself. But to rule that out try taking a pic if you cannot you might got a shutter issue as well.
Thanks hope the information helped
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
I have a Cybershot DSC-S780
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 07, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Blank Screen
I have been facing the same problem with same model and this is permanent problem it seems with this model (Sony Cybershot DSC S40). It causes because of the following:
SYMPTOMS
LCD display is either blank or WHITE. When the cabinet is opened or LCD flexible cable is
touched, the symptom disappears. This is caused by connection defect or poor contact between connector and LCD flex cable due to the pressure or stress created by the rib in the front cabinet
to the connector.
Send me a email and I shall send you the solution (two files) received from Sony authorized person. You have to open the camera to solve this. Do not open the camera . Just get the idea about where the problem is. I never opened the camera even after seeing this solution 2 yrs back. However, I have a plan for going to service centre with this solution. I hope they can open the camera and solve this. But not getting time to go there in service centre.
I used the following temporary solution and it works to get LCD in its normal condition:
LCD looks like a rectangle is not it? Hold the camera in its normal position as you are going to take a picture (camera is switched on and you are not seeing anything in the LCD, which looks white or dull). Now GENTLY PRESS by the thumb of your right hand at a place near to LCD at the BOTTOM RIGHT CORNER of the rectangle (remember not on the LCD (rectangle) but just outside of it) until you see the normal colour of your LCD. Do few times starting with less pressure and then slightly increase it untill you see a normal LCD. I have been following this procedure for the last 2 yrs and not feeling to go for serving. (This solution I found in a forum only).
(mondal_ashok (at) rediffmail.com
Nov 16, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cyber shot
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 21, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot touch screen camera
maybe..it's have a picture tube problem..i think that you should go in a proffesional to fix your camera..that's only my opinion..thanks
May 20, 2008 | Sony Cybershot S650 Digital Camera
Can't see through lens, dropped camera
Sound like it needs repair.
http://esupport.sony.com/?ref=http%3A//www.sony.com/index.php
Above is a link for your camera, there is a chat button on the right, you might want to try it.
Jan 23, 2008 | Sony Cybershot S650 Digital Camera
PLEASE HELP!
There is a problem inside the camera with the wire harness/cable connection to the screen. They are know to come loose over time. If you tap rather briskly on the front of the camera right on the word Cybershot it should reconnect it. Worked on mine but you may need to do it now & again. The altenative is to have the camera dismantled and the connector pushed back onto the screen.
Now a couple months later I have a different problem, it says to turn the power on and off again when I turn it on to take pictures.
Nov 18, 2007 | Sony Cybershot S650 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
245 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
