Question about Boating
200 hp suzuki outboard runs rough in mid rpm range
Starts and runs fine at low and high rpm's, but from about 2000-3500 rpms it runs rough. Seems to run fine once it comes out of the hole. I have changed the filter, changed and gapped the spark plugs, and looked all over for loose or worn connections.
  • 5,687 Answers
You may need to syncronize the carbs. Run it and mark the throttle lever for your problem areas so you can duplicate the throttle position on dry land. When on land move the throttle lever to the problem area and then remove the engine cover. NOW look for loose connections and fittings especially carb linkage. At the worst you may have to have each carb adjusted with a flow meter if you do not find a worn part. A good boat shop will have such meters.
Posted on Jun 25, 2009
What is wrong wIth my Honda xr 125 idle?
have carb cleaned ethenol kills carbs
Mar 22, 2015 | 2005 Honda XR 125 L
2005 Dodge Ram 1500 4.7 Engine. Starts fine, Idles fine, but when engine shifts into high gear and RPM lowers engine runs really rough under load
Have you checked for a broken valve spring. Repaired a dodge engine with the same running issue as you have described and it was a broken intake valve spring.
Feb 22, 2015 | 2005 Dodge Ram 1500
Runs rough
did it have a K&N before?? or check sealing correct.
Apr 13, 2014 | Suzuki VL 800 Volusia Motorcycles
2006 Suzuki King Quad sputters at high RPMs like it's breaking down. It starts good and seems to run alright except in high RPMs.
Make sure you have the CORRECT spark plug... use what the owners manual says... NGK..
. A non - resistor plug will make some motors sputter at high rpm's ...if the quad calls for a "R" plug..use one!
Mar 25, 2014 | Suzuki 2007 KingQuad 700 4X4
05 Bandit 1200S idles low, run rough at low rpms,
Try buying new diaframs for your carbs, because of the diafram and piston operation, if the diafram becomes weak due to heat from your engine, and by the diafram not beeing rigid enough, it hesitates to lift the needle out of the jet causing the lack of fuel at low tack/rpm when throttling up or accelerating slowly.
Jun 11, 2010 | 1997 Suzuki GSF 1200 Bandit S
99 gsxr 750 losing power after 10k rpm if you have
The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen.
Mar 07, 2010 | 2007 Suzuki GSX-R 600
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Bike loses power in the mid rpm range
Try the air filter first (make sure it's clean). The needle valve on your carb slider could be bent, or not seated correctly or just set wrong. If you have a power exhaust valve, it could be set wrong or malfunctioning as well. Good luck.
May 14, 2009 | 2003 Yamaha YZ 250
Boating Logo
576 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
