Question about Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Describe your Kenmore 24032 24036 Top Load Washer Problem
I have a small leak out in front of my Kenmore 800 series washer. Its not the hoses, I checked. Every time I do a load a see a small amount of water along the side of the washer. I can live with it but it is a mess to clean up every time I do a wash.
    President:
  • 3,113 Answers
Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
Posted on Jun 16, 2009
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer leaks after replacing water pump
front loader or top loader we can not guess
Sep 13, 2017 | Kenmore Washing Machines
That is a bad water valve. Try my washer PICTORIAL for directions on replacing that water valve. NOTE: this is a pictorial of how to replace your drive coupling but you need to bust this ****** loose to get to that valve.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jun 30, 2009 | Kenmore 24032\24036 Top Load Washer
Hi, Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
If this is not your model, please let me know the model# so I can help you.
Vic
Jun 28, 2009 | Kenmore 24032\24036 Top Load Washer
Small leak/drip at on the front side of the washer..
possibly water pump you need to get fix asap cause it could start fire!!! Good Luck!!!!
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
305 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
