Question about LG hbs-730 Tone Stereo Bluetooth Headset
One side is louder
One side is playing louder how can I fix it to equal
DIGITAL S METER READING TOO HIGH WHAT VR POT TO ADJUST
please follow this steps and fix it. GOD BLESS you
    • 1
Turn on all of the devices in your sound system. Turn off any auto-equalizers on your sound system to gain fullest control over frequencies. This switch might be found on the receiver or the equalizer itself.
    • 2
Play a test song on repeat. Choose a song with both extremely high and extremely low instruments so that you have a wide frequency range to listen for.
    • 3
Listen for any obvious distortions in the highs and lows of the songs. Lower the knob on your equalizer for any distorted frequencies until the distortion disappears. Try at first to find the highest setting possible without distortion.
    • 4
Adjust all frequency ranges in relation to each other to find a pleasing blend for your room, trying not to let any one frequency range dominate the others. Use the highest non-distorting settings found in Step 3 as maximum settings, but don't be afraid to lower a booming bass or a screeching flute that disrupts the overall blend of the music.
    • 5
Play a song from a different genre to test how the EQ works for different types of music. A hip hop song will have louder lows than a string quartet, for example, so make sure your bass frequencies sound crisp on both types of music.
Nov 07, 2013 | Magnum DeltaForce CB Radio
How do I fix an eq problem?
It is a skilled work.. Seek tech support.
Jun 03, 2012 | Audio Players & Recorders
How to make your phone play louder
Fix equalizer settings, if you have, put it all on top.
Mar 17, 2011 | LG KS360 QWERTY Keyboard Phone BRAND...
PLAYS SOFT WANT IT LOUDER
Try putting your equalizer in manual mode, then move all the bars to the highest possible, put the volume to maximum and heard. If it distorts sound, then move one of the bars one step down. Be moving one on one until you get a balance between volume and quality that fits your needs.
Nov 21, 2009 | LG Shine KE970 Cellular Phone
My amana washer makes a whril noise when it spines.
UNFORTUNATLY IT IS PROBABLE A SPIN BEARING THAT IS MAKING THE NOISE. THIS IS USUALLY CAUSED BY A LITTLE WATER LEAKING FROM THE CENTER SEAL ONTO IT. IT IS VERY EXPENSIVE TO FIXED AND VERY TIME CONSUMING, PLUS YOU WILL NEED SPECIAL TOOLS DESIGNED FOR THE JOB
Aug 11, 2009 | Washing Machines
The background music is louder than the voices
try resetting the equalizer in your wm player...
May 22, 2009 | Microsoft Windows Media Player
One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Dec 24, 2008 | Logitech X-530 Computer Speakers
Car equalizer not completely working
you may have use the audio input signal port on the unit
Oct 17, 2008 | Car Audio & Video
My speaker sound
hi
if u realtek or any sound card then first set equalizer of that
raise left 2 or 3 bars foe bass,middle for vocal & right for treble
also set in the same way of ur player used
Apr 06, 2008 | Audio Players & Recorders
LG hbs-730 Tone Stereo Bluetooth Headset Logo
109 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
