Question about Hitachi Touro Computers & Internet
Touro not recognized with my windows XP
My name Omer; last name Shimer e-mail:love4goldenpig@yahoo.com In My Device Manager the Universal Serial Bus Controller shows that I have USB mass storage device. My Taskbar also shows I have a Mass Storage Device. But NO EXTERNAL HARD DRIVE trace in MY COMPUTER and cannot see trace of my external device when I right click any file to copy on my Touro. HOW CAN I FIX THIS ISSUE. HELP PLEASE.
laikexpert
  • 281 Answers
SOURCE: Disk does not show in explorer window
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 02, 2010
siawolf
  • 749 Answers
SOURCE: Hi I am running Window Me and my freecom external won't work
unplug its usb cable and plug it into a different usb port
Posted on Mar 30, 2010
issken
  • 1472 Answers
SOURCE: Can't see Seagate external hard drive on Vista devices with remov
dougv52
If the drive is not showing up in My Computer but is showing in Device Manager then you most likely need to assign a drive let you the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 18, 2010
  • 61 Answers
SOURCE: I just got a 250GB Iomega eGo external hard drive
You may assign a drive letter to it by going to Start
  • right click computer
  • Select Manage
  • Go to disk management
  • select the drive It may be displayed as Disk 1 or Disk 2 (depends on your confug)
  • Change Drive Letter
  • Assign a Drive Letter
  • It should display on your computer
  • If you have not data on it, you may format it by going to Start and
    • Select Manage
    • right click on the drive and select format it.
    Posted on Oct 30, 2010
    Testimonial: "Very helpful. "
    • 389 Answers
    SOURCE: I have an external hard drive made by Gigaware.
    If you have not used the external hard drive before, you will have to go into your drive management and initialize your drive and possibly format it. The fact that your computer recognizes it is a good sign. It means that the external drive is working properly and the computer recognizes that the external drive is there. I have an short paper I have written describing how to use the drive management utility in windows. It is too long to post here. I can either post part of it or you can give me your email and I will send it as a MS word attachment so you can have the entire paper.
    I hope you find this helpful Brian
    Here is the part I can post here:
    Using Disk Management Utility
    Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
    Right click on you "My Computer" Icon
    A menu will open
    Chose "Manage"
    The Computer Management window will open
    The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
    The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
    The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
    Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
    This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
    A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken.
    Posted on Dec 27, 2010
    No usb ports recognized
    W 7
    First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
    In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
    Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
    Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
    for XP or earlier
    Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
    you will need to update/reinstall drivers right click to reinstall drivers
    if you can see your usb drive but its not working
    ports (com&lpt) right click update driver if this fails to fix the problem
    Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
    if you need more help with this or if i have missed the problem post a reply
    Mar 25, 2014 | Systemax Venture C11R PC Desktop
    Drive not recognized device
    1. Click Start, then type device manager in the Search box, then click Device Manager.
    2. Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
    3. Once complete, restart your computer. Your USB controllers will automatically install.
    Nov 20, 2013 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
    Why the windows7 cannot recognize the usb cable device of psvita
    w7
    Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
    MY COMPUTER DOES NOT RECOGNISE THE IPOD TOUCH AT ALL ALTHOUGH IT CAN CHARGE ITSELF
    Solution 1 -
    1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
    2. Click to select your computer as the location for the scan.
    3. On the Action menu, click Scan for hardware changes.
      Windows XP recognizes the new device.
    4. Close the Device Manager window.
    Solution 2 -
    3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
    4. Click the Power Management tab.
    5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
    6. Repeat steps 3 through 6 for each USB Root Hub in the list.
    7. On the Action menu, click Scan for hardware changes.
    8. Close the Device Manager window.
    Feb 02, 2010 | Apple iPod touch
    Cruzer SANDISK 4 GB ceased being recognized by Windows Vista
    it may be necessary to uninstall and refresh the USB drivers. This requires Administrator permissions:
    1. Open the Control Panel
    2. Double-click System
    3. Click the Hardware tab
    4. Click the Device Manager button
    5. Expand the Universal Serial Bus controllers section by clicking on the "+" symbol beside it.
    6. Right-click on each of the hubs and devices you wish to reinstall (often named "generic hub" and "mass storage device") and select Uninstall
    7. Reinsert the device and allow Windows to detect the device as if it were new
    Mar 22, 2009 | Computers & Internet
    USB device not recognized
    Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> Universal Serial Bus Controllers - look to see if there are any yellow exclamation marks next to any of the USB ports. If so, right-click them and select Update Driver. Good luck!
    -Tha Mp3 Doctor
    Feb 07, 2009 | SanDisk Sansa MP3 Player
    Acer extensa 5620
    i have laptop acer extensa 5620z, install windows xp professional os 32 bit, inside device manager open that time
    Ethernet controller
    Ethernet controller
    Mass storage controller
    Pci device
    Pci device
    SM Bus controller
    Universal serial Bus (USB) controller
    biling the yellow(!) mark, and usb device put in the usb port not open how to solve this problem, please reply me, thankyou,
    my email senthil_japan@yahoo.com
    Jan 26, 2009 | Acer Extensa 5620 Notebook PC
    Usb ports not working
    1. Checking USB device status in Device Manager
    1. Right-click My Computer on the Windows desktop and then click Properties.
    2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
    3. In the Device Manager list, click the + sign next to Universal serial bus controller.
    4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
    5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
    6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
    7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
    8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
    USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
    1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
    2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
    3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
    4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
    5. Follow the onscreen instructions to save the new settings and restart the computer.
    1. USB controller or root hub disabled in Windows Device Manager
    2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
    4. Click the line in the Device Manager containing the red X.
    5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
    6. In the Communications Port Properties box, click the Resources tab.
    7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
    Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
    Hard drive not being recognized
    dear ramroot
    enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
    trying to connect your ext. Harddisk again
    oke
    cropp
    Mar 17, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
    Ipod not found on window xp
    right click on computer then
    1. click properties
    2.hardware
    3.device manager
    4.universal serial bus controller(open the + sign)
    5.click upper one double click
    6 go to driver
    7.click on the update driver
    8. then choose second one (advanced) then next
    9.click don't search
    10.then next next if it is over
    same process with anotherone then restart your computer and enjoy you ipod
    and don't forget to give rating
    and if you want any song like gree n day you acn contact me at mango4529@rediffmail.com
    Nov 15, 2007 | Universal Remote Control NspireGear MP3...
    Computers & Internet Logo
    79 people viewed this question
    Top Hitachi Computers & Internet Experts
    Alun Cox
    Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
