Question about Generac XP10000E XP 10000 E 5932 Portable Power Generator 10kW
Generac gen 10000xp will not start not getting fuel
I have replace the carb only way to get the fuel silonid and now i replace the electrical board still will not get fuel . if i pour fuel in the carb fires right up. i dont no what else to check any suggestions
2 Suggested Answers
  • 26 Answers
SOURCE: Generac Watchdog 15K, engine will not start
throttle motor or governer board. or control board. your gas line could be to small. check the pressure while its cranking to see if it drops. watch the throttle to see if its moving while trying to crank the generator
Posted on Aug 28, 2009
I was running my 11k gen in the manuel position cold weather when doing this I reved the engine up and it stopped on over speed how do I reset the alarm
not sure what unit you have or if electric start...but elce start then disconnect the battery for 10 minutes and re-connect. Clears the code on generac and some other manufacturers.
former generac rep.
Hope this helps.
Jan 01, 2018 | Cars & Trucks
I have a duromax gen dual fuel clean carb in soni bath .new fuel have spark .still wont fire up
hi
check for compression on cylinder and ignition timing /
and ensure of fuel getting in the combustion
Dec 03, 2017 | Generac Electrical Supplies
Generac 15000 4582 won't start - seems to be flooded - blowing fuel out of exhaust - carb solenoid checks out but fuel flows into carb even when off
Carb. Sol. Can work electrically but the seat may not be sealing. Would remove and clean. Also place shutoff valve in fuel line and always turn off when storing.
Sep 12, 2017 | Garden
Generac troubleshooting
Check the oil level and the spark plug.
Sep 01, 2014 | Electrical Supplies
Generac ix 2000 how do I adjust fuel mixture
im not suure what you mean about "Bog" but this gen is only good to 1600 watts cont. (2000 peak) and it has a auto throttle so it will idle down all by itself when not loaded past say 40% of total load , but if you think your having fuel starve problems try all the simple things 1st Fuel filer (inside tank) clean carb and stuff like that , I do fix allot of small engines with a good strong dose of stp fuel treatment and i never need to take em apart
May 30, 2014 | Generac Ix2000 Portable Generator Inverter...
Is there fuel in the carburetor Bowl?
did you try running a separate gas line from a different gas tank to the carburetor?
Apr 01, 2014 | Generac XP10000E XP 10000 E 5932 Portable...
Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Apr 11, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Generac XP10000E XP 10000 E 5932 Portable Power Generator 10kW Logo
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
