Question about Uniden Radio Communications
How do i tune my uniden tl22-dv television
I can't seem to get any channels tuned in
SparkGap
  • 363 Answers
SOURCE: TUNING IN A TELEVISION
Please could you provide a Manufacturers name and the model of TV. One of us might be able to find a manual for you. Cheers.
Posted on Sep 28, 2007
  • 86 Answers
SOURCE: tuning problem
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Posted on Jan 30, 2008
SOURCE: Tuning
Same here. I have the tv with a hitachi r/c CLE-87613 but can't tune the tv to the aerial channels.
My email is tonyhutchinson@hartsheadgroup.co.uk
Posted on Mar 25, 2008
  • 3600 Answers
SOURCE: i cant tune my Uniden BC60XLT-1 Handheld Scanner
you need to know the frequency you want to listen in on like local fire police and sheriff and ambulance channels you can go to bear-cat web site and they have a company there that will give you the scanner frequencies in your area code so you can store then to listen to them, you can also get the Freq. for the 1.2 million UN peace keepers in the U.S. as well. However you need to im put the frequencies manually and you need the manual so go to the web site for the uniden it's http://www.uniden.com and read how to store the freq. codes in the scanner. it will tell you how many you can store I think it's up to 10.
Posted on May 29, 2009
SOURCE: peak tune
I need the tx meter on a galaxy saturn,can you find one for me.ùthank you very much
Posted on Jul 30, 2009
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
I have a Uniden Bearcat 30 Channel 10 Band Radio Scanner how do I program it when I put in the number it shows error
The ERROR message usually indicates that you've tried to program a frequency outside the scanner's tuning range. The BC60XLT top tuning range is the 512 MHz band, so you cannot tune any 800 MHz frequencies. For further information you can download and print the factory manual, at no cost, here:
http://www.uniden.com/pdf/BC60XLTom.pdf
Bill B.
Listening in since the 60's
Apr 01, 2011 | Uniden BC60XLT Handheld Scanner
Have tried twice but do not seem able as channels seem all over the place . do not have manual.
Hi, the problem will not be with the remote control. It sounds like you are performing an autoscan when tuning your television. The only time this process works is when all the channels are in order and there are no weak stations in between that could be potentially picked up by the television.
Do you have a manual for the Television as all you need to do now is to sort your channels in the tuning mode.
This should fix your problem.
Hint - Google is your friend
Mar 20, 2010 | Televison & Video
I have just been given a Panasonic TC-29V26A colour TV in perfect working order. I connected my Digital box to it and had no problem, I just can't get any non digital channels to tune in...even following...
U only get digital channels,that work propperly notthing wrong.Get a digital antena might all the other digital not getting.Non digital will not tune in any more.
Feb 10, 2010 | Televison & Video
Will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
Jul 27, 2009 | Panasonic TX-26LXD1 26 in. LCD Television
Dv device is not connected
DV is a digital device, used for digital Cameras.
Have you got the cabling correct ?
alternatively, try tuning the dv device into a television channel, or vice-versa.
Mike @ compurepair.
Nov 05, 2008 | Samsung DVD-AR650
Peak tune
take it to a cb radio repair shop ,tell them to peak and tune to its max
Apr 06, 2008 | Uniden Bearcat Pro PC68Elite 40-Channels...
My free view
Define "tune" please. Tune channels, tune hi-def channels, tune picture performance, or something else altogether?
Feb 10, 2008 | Televison & Video
Radio Communications Logo
23 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
