Question about Garden
Not going into gears
Can't get it into gear to drive
3 Suggested Answers
  • 65 Answers
SOURCE: gear switching problem all gears go into drive
there is a cable leading from your gear selector to a lever located on top of your transsmission this could either be broken inside the cable or unhooked on either end hope i could help
Posted on Mar 23, 2009
  • 156 Answers
SOURCE: gears stick
If your car is a manual gear change, your clutch may need adjusting or repair or the gearbox oil may need changing.
If your car is an auto check to see if you are using the correct transmission fluid , Peugeot autos do not use normal ATF and will fail if the correct fluid is not used.
Hope this helps Marshall
Posted on May 26, 2010
50 horse 4 stwont go into reverse gear due to shaft problems
the drive shaft just drives a pinion gear in the prop box that drives to gears that spin in opposite directions all the time
by selecting forward with the selector rod , a dog gear is moved forward to mesh with one gear that is turning or moves the other way to engage the other gear that is turning
that is the forward or reverse action for the prop
if you have forward but no reverse the it is not a drive shaft problem but a selector rod adjustment that is not moving the dog far enough to engage the running gear
Jul 08, 2017 | Cars & Trucks
1988 Dodge Ram 50 Automatic shifts into park reverse and neutral. But physically won't go into drive gears.
Disconnect shift cable from transmission linkage and try to manually put transmission in drive gear ( make sure wheels chocked/park brake on ). If transmission goes into drive gear, suspect a shift cable or shifter assembly problem. If you can't manually shift into drive gear by hand with cable disconnected, suspect internal transmission/shift linkage issue
Mar 10, 2016 | Dodge Cars & Trucks
Toro timecutter starter
I think this is going to be like an automotive starter.
You will need to check 3 things.
The ring gear where the starter gear cranks the engine, the starter gear that engages the ring gear, and the overrunning clutch or bendix , which is the springy part that kicks the drive gear into the ring gear.
When you remove the starter from the engine, you will see the drive gear on the end of the starter that was inside the motor.
The drive gear is about the diameter of a half dollar or a silver dollar. it should not be chewed up, it should look like a good gear. Inside the place where the starter attaches, you should see a ring gear, with a flashlight, and those teeth should look good and not chewed up.
On the starter you removed, behind the drive gear and usually inside the starter is the bendix or overrunning clutch , which will push the drive gear into the ring gear when you crank the starter. These parts often fail every few years.
Some people fix them, most people replace the whole starter.
Be blessed.
May 05, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
Transmission goes into nuetral when overdrive is ingaged
over drive is a gear its self it may be going out in the trany so when that over drive button it pushed it thorws it in to that gear that may be out no and it dont matter is you try to sift because it is a gear its self my car is 4 speed drive 1 drive 2 drive (3 gear) and overdrive (4th gear)
Mar 07, 2013 | Cars & Trucks
What is the second drive gear for
The first one is over drive and the second is drive. It is best to just use overdrive when on the parkway and drive on slower back roads when there is hills and stop and go traffic. Overdrive is a higher gear.
Dec 09, 2011 | 1998 Ford Taurus
Ford Escape Automatic Only Goes Into 1st Gear Manually
it sound like you have a vacum leak or your shifter cable may need adjusted
Oct 26, 2009 | Ford Escape Cars & Trucks
Gear switching problem all gears go into drive
Mar 23, 2009 | 1993 Dodge Caravan
Car will not go into gear and clutch feels unpositive
try thinner oil in the gear box also bleed the cluch and adjust it this should fix the problem
cheers tricky85
Sep 06, 2008 | 2001 Volkswagen Golf
2008 avenger
sounds like the brake shift interlock solenoid
Jun 25, 2008 | 2008 Dodge Avenger
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
