Question about Soundstorm S7EQ 7-Band Car Equalizer
Speaker wires have 4 wires from back of eq. now i have 4 sets out of deck with 2 for each set. wich wires do i hook up to make speakers get eq. boost. i have power and that all work just no speaker boost
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
Head unit connect
You will only be able to use this EQ on the front or the rear speakers. You will have to get another EQ if you think you need one. Usually, the front speakers of a car's audio system are the smallest and the rears are larger. You really do not want an EQ on the subs. If it was mine, I would hook the EQ between the head unit and the rear speakers. If you feel this does not sound right, you may need, but I doubt it very much, to get another EQ for the front speakers. Good Luck
Aug 18, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
I have a panasonic SA AK25 with no manual.There are 2 sets of wires coming out of the speakers .how do i hook them up at the back ,thanks
you need a basic meter to ohm out the wires. most speakers ohm out around 8 ohms. some speakers have wires that can hook up to more speakers. others use an external power source to boost the output of the speaker. I would ohm out the wires and find the closest thing to 8 ohms. then with a small 1.5 volt flash light (AA) or (AAA) battery you go across the wires that you think are the load (speaker) if you hear a poping or crackle sound then you have found the wires that are the speaker wires. this would be the wires to hook up to the amp.
May 01, 2011 | Panasonic Audio Players & Recorders
Need the wiring diagram for a realistic eq booster model no. 12-1955
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
Apr 16, 2011 | Car Audio & Video
Hi there...i'm having a little problem installing my pioneer avh-p6600dvd unit...couple questions. I can't seem to identify the accessory line for the unit what color is it? Do i still need the brain even...
on the back end of the deck there are a series of wire thats attached to a push-in plug.you will find:
plain yellow-wich goes to permanent live(12-14v)
red -wich allso goes to permanent live(12-14v)
black-wich goes to ground/earth
light green-wich goes to ground/earth
blue and white-wich goes to the ignition wire of your vehicle(remote)
2 x green(rear speakers)
2 x purple(rear speakers)
2 x white(front speakers)
2 x grey(front speakers)
Mar 06, 2011 | Pioneer AVH-P6600DVD Car DVD Player
I have four bose 901 speakers and one equalizer. I also have a peavy deca 424 amplifier. I have a tape deck with the tape monitor capabilitity. Can these work together and how do I hook theme up?
The presence of 1/4" TRS balanced phone jacks instead of RCA inputs is a problem; and the 1/4" TRS speaker output jacks, too. You'll need to acquire cables with compatible ends.
The amp can handle 4-ohm loads so running two 901's parallel on each channel would theoretically work, but I'd put them in series just to keep from presenting too low a load when you get cranking. At 230 wpc you've got the juice. From Series 4 on the 901's are very efficient.
The Tape Deck will attach conventionally to the Tape Loop on the Active Equalizer.
Once you get the physical wiring compatibility issues worked out:
Patch the Active EQ directly between any source you may be using (Amp In from the Pre-Out of the source, Amp Out to the Peavey input).
You can record the external source onto the attached Tape Deck and you can monitor it by pressing the Tape switch on the 901 EQ.
Start out at low volume and see how it works before turning it loose.
Dec 28, 2010 | Bose 901 VI Main / Stereo Speaker
How should I place the tie mic
Typically you want to wear the mic 6 to 8 inches below your chin clipped to the lapel area. It seems in this case it has more to do with EQ and speaker placement. If you can stand behind the speakers while using the mic. The sound bouncing back and forth between the mic and the speaker is what causes feedback. Also try setting the mic channels EQ with the following settings.
Turn Lows down to about 7 to 9 O'clock
Play with Mids to match actual source, but never boost above 12 O'clock
Keep highs around 10 O'clock (boosting highs increses chances of feedback.) If to muddy sounding keep highs aroun 12 but not over.
Good Luck
Oct 08, 2009 | Audio Players & Recorders
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Jvc kd-g720, hook up eq
yea but you will only have control on the low side of the eq. your beter off using that eq for your mids and highs
Oct 02, 2008 | JVC KD-G720 CD Player
Wiring question
Hi, If I got the specs right, your amp is a 4 channel hence the 4 RCA inputs. Probably the simplest would be to feed the 2 X RCA out of the deck to the 1 & 2 RCA in of the amp. This amp has also a line out, feed the amp's lineout back to the 3 & 4 in. This way, all four channels get same input from the deck and you will have identical power to all 4 speakers (front & rear). An afterthought is to also use the 4 outputs of the deck (since they are there anyway and it is not a good tech practice to leave outputs without load/speakers) and connect 4 mid-range or 4 smaller speakers. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 02, 2007 | Performance Teknique ICBM-774 Car Audio...
Soundstorm S7EQ 7-Band Car Equalizer Logo
27 people viewed this question
Top Soundstorm Car Audio & Video Experts
Coss
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
