Question about MSI Computers & Internet
Msi S6000-16D3 boot disc
Boot cdrom
Cannot boot from cdrom
Upgrades do not boot, they are installations to a working OS. Boot your laptop and insert the disc then run setup from the disc.
Nov 15, 2013 | HP 6710B, Intel Core 2 Duo T8300 2.4GHz,...
NEED BOOT DISC FOR MSI 760GM-E51(FX)
Hi Mr. Smith,
You cant find that boot disket on internet. Only MSI peoples can help you. Here is the download link for you.
So.. happy download and write everything on a CD/DVD first.
Link : http://www.msi.com/product/mb/760GM-E51--FX-.html
Mar 16, 2012 | Computers & Internet
Unable to boot from cd in MS6188
go into BIOS and set boot up options to boot to CDrom first
Sep 05, 2010 | IBM MSI MS-6188 (49P3492) Motherboard
How to install windows xp in lenovo G460
if you have the windows XP disc. put it inside the cdrom drive then restart the computer. keep on tapping the F12 key once the computer is restarting. you will be rprompted with boot options. select your CDrom drive as boot device then hit enter. your computer should boot now using the cdrom. XP installation should be running now.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 07, 2010 | Computers & Internet
How to use recovery disc for fujisu siemens amilo 1818 please
Go into BIOS, set to Boot from DVD, place DVD in PC, reboot with keys CTRL__ALT___DEL all at once, it will Boot of the DVD, and follow instructions.
Mar 28, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
Can't install windows from cdrom
replace your cd rom, otherwise you can run win setup from usb flash memory. maybe if you clear your cmos/bios memory your cdrom will reconect and you will create partition/format your hd and installa fresh windows operating system.
this will resolve your problem
thanks
Apr 27, 2009 | IBM ThinkPad R40 Notebook
I can't load my drivers dor the cdrom
google win98 bootdisk
the floppy you create will have them.
or just boot the win98 cd and there they are.
Feb 04, 2008 | Microsoft Windows 98 for PC
I am not able to boot from cdrom of my system
Enter pc bios. can you see your cdrom listed in the MAIN menue? Goto Boot. Set your cdrom to first boot device.
Make sure you have a bootable CD in the cdrom. Still can't boot to the cdrom? Think about swapping it out or getting a new one.
Jan 17, 2008 | MSI KM4M-L Motherboard
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
44 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
