Question about D-Link DIR-615 Wireless Router
Forwarding ports I can not seem to get to the page to forward ports
    Champion:
    New Friend:
  • 219 Answers
Try this link, it explains how to forward ports for the DIR615:
http://portforward.com/english/routers/port_forwarding/Dlink/DIR-615/
Posted on Aug 14, 2014
Benimur
  • 6966 Answers
SOURCE: removing open port
Have you tried a full hard reset? This is done by pressing on the small recessed button at the rear of the unit. Of course all settings would revert back to factory defaults. Perhaps it may be to your advantage to notedown certain informatin such as your WAN IP configurations, security key etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 17, 2008
Styme
  • 84 Answers
SOURCE: port forwarding
open up BitTorrent , then go to view , then select settings ,
next box open up network tab , in starting at point type in 6881. Then you want to open up you adsl router
to do this type in your IP address it should be 192.168.1.1 ( just type those number into browser )
When page appears login name and password just click login
Then go to advance and then to port fowarding and select user at bottom then click add . ( rule name can be the bittorent site you wish to use .. aka edonkey )
The TCP should read 4672 for all three and the UDP should read 9919 for all three .
Select apply then select tools ontop select save all
Posted on Jul 31, 2008
  • 35 Answers
SOURCE: Port Forwarding in DI524
Log into router
- Default ip should be 192.168.0.1
- Go to advance settings
- Open ports that are needed
- save settings
Posted on Aug 19, 2008
webdevil
  • 43 Answers
SOURCE: port forwarding GLB-502Trouter With utorrent
Here is a link to the specific steps you need to setup port forwarding on the GLB-502T
http://portforward.com/english/routers/port_forwarding/Dlink/GLB-502T/Lingo_VoIP.htm
Posted on Dec 29, 2008
  • 58 Answers
SOURCE: Port forwarding on dlink adsl2 router
Step 1. Before you open ports in your router, set the computer (or the device) which requires
ports to be opened for, with a static IP address. You can choose any IP address from the
range of addresses you are using on your local network, as soon as it is not used by any other
device. The default range is from 10.1.1.2 to 10.1.1.254. In our example we are using
10.1.1.99.
Windows XP: Control Panel > Network Connections > Local Area Connection > Properties >
Internet protocol TCP/IP > Properties
Windows Vista: Control Panel > Network and Internet > [Network and Sharing Centre] > View
Network Status and Tasks > View Status > Properties > Internet Protocol v4 > Properties
Select the “Use the following IP address” option:
IP address: 10.1.1.99
Subnet mask: 255.0.0.0
Default Gateway: 10.1.1.1 (your router’s address)
DNS: 10.1.1.1 and 61.88.88.88 (or whichever your provider is using)
Now open the necessary ports in your router and redirect the traffic to the 10.1.1.99 address.
Here are the steps:
How to open ports in your router Page 2 of 6
Step 2.
Open your web browser and enter the IP address of the router (http://10.1.1.1). Enter
user name and password (default username “admin” and password is “admin”).
Step 3. Click on Advanced at the top and then click on LAN Clients.
How to open ports in your router Page 3 of 6
Step 4
. You will need to add a LAN Client (the address of your computer or a device) into the
router before you can open any ports. Type in the IP address of the Computer/Device (the
one you assigned in Step 1). You can specify the name of this workstation under Host Name
(optional). Click Add and then Apply.
Step 5. Go to Advanced > Virtual Server (Port Forwarding). There is a list of pre-set ports in
the router which you can choose from.
How to open ports in your router Page 4 of 6
Step 5a.
If your specific application is not listed there, you can add the necessary ports
yourself. Select the “User” Category and click on Add button below.
Step 5b. Enter a name for this entry under Rule Name. Then select the necessary protocol. If
there is a range of ports to open, specify the starting port under Port Start and the ending port
under Port End. If you need to open just one port, specify this port number in all fields
including the Port Map. Click Apply.
How to open ports in your router Page 5 of 6
Step 6.
Go back to Advanced > Virtual Server. Under LAN IP select your LAN Client (which
you added in Step 4). Select the Category and the desired Rule or select “User” Category
and you should see the rule which you have created in Step 5b. Select it and then click on
Add > to move it into the Applied Rules section. Click Apply.
Step 7. To save the new settings into the router's memory go to Tools > System. Click on
Save and Reboot button. The router will save the settings and restart.
Posted on Jun 21, 2009
Port forwarding
In your router's setup menus, click Advanced Setup, then click NAT, then click Virtual Servers.
That's the port-forwarding configuration page for Primatel routers.
Feb 10, 2014 | Computers & Internet
Where do i find the port forwarding?
To access the Port Forwarding option of your router, you will need to access the router setup page and from there you will find Application and Gaming tab and there you will see the sub tab port forwarding that is where you can open the port that you need to work behind the router.
Aug 12, 2011 | Linksys WRT54G2 Wireless Router
Trying to establish a port forwarding for my IP cameras
Port forwarding can be done using the routers configuration. Make sure that you have open your router page select Port Forwarding . Check this out for guidelines : http://portforward.com/
Jun 04, 2011 | D-Link DFE-528TX Network Adapter
HOW CAN I FORWARD A PORT? THIS ROUTER IS NOT LISTED IN PORT FORWARDING APPLICATIONS LIKE SIMPLE PORT FORWARDING ETC.. OR SUGGEST ANY OTHER WAY TO FORWARD PORT
In order to get to the page you need to port forward you need to know your default gateway.
Usually:
192.168.0.1
192.168.1.1
192.168.2.1
Enter those into your web browser, if nothing comes up then go to Start. Then click run(or search if you have vista) type "cmd" then type in ipconfig
Start>Run>Cmd>Ipconfig
There is where you can see your default gateway. Enter that into you browser. I t might ask for a password, it's usually admin.
Also a lot of the port forwarding issues are due to your firewall settings. Make sure you add the ports to there as well.
Jul 10, 2009 | Computers & Internet
I have a Wrt54g wireless router hardwired to my computer and xbox. I have followed the instruction on portforwarding.com on opening certain ports. Nothing i do seems to work. im starting to believe its...
you have to do port forwarding in the router go to the router configuration page then Nat or port for forwarding option is there give there your x box port number then you get it
Apr 21, 2009 | Linksys Wireless-G WRT54G Router
Port forwarding & Remote Management setup on Linksys WAG200G
here is how you set up port forwarding:
1. log into the router;
2. Click the Applications & Gaming link near the top of the page. 3. You should now see a new menu. Click Single Port Forwarding or Port Range Forwarding.
4, Enter sth like: HTTP; 80; 80; TCP; 192.168.0.1; check
5. When you're finished, click Save Settings near the bottom of the screen to save your changes.
go to administration-> remote administration to set up remote management
Remember, remote Administrator requires you to forward the 4899 ports.
Mar 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Port forwarding my wireless interent linksys and netgear
access the admin page by http://192.168.0.1 - If you have the manuals, you should be able to access port forwarding with the admin page.
Manuals are avail. online, as well.
May I ask, what do u need to setup for port forwarding?
Oct 24, 2008 | Computers & Internet
Port forwarding
Go to the routers setup page labeled port range forwarding, and type in the necessary information in order for your item to work.
Apr 13, 2008 | Linksys Wireless-G Broadband Router
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
Hope this helps.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
Port Forwarding
there is a way for you to port forward to anything that you would want, the only thing that you would need is the port numbers in order for this to work. Using terms.
1.) In your address bar, type in, "192.168.0.1". And by default, your username should be blank, and your password is, "admin".
2.) Once onto the mainpage, look up at the top of the page, and go into advance.
3.) And then look on the left hand side, and click into a tab that says, "Forwarding".
4.) Fill in you information/chart.
a.) Easiest way to find your ip address is to go to, "Start"(bottom left of your screen), click "Run", and then type in, "ipconfig/all".
b.) Enter in your Start and Exits ports like I said in the beginning.
c.) TPC/USP
d.) And then click "Enable" box, and click, "Apply" at the bottom, and your done!
Jul 27, 2007 | RCA Cable Modem DCM315R (11603540)
D-Link DIR-615 Wireless Router Logo
63 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
