Panasonic PT56TW53 red light blinks and no picture
We had the same problem about two years ago. The repair slip says Qty 2 stk392-110. Is this something that we can fix ourselves ??
  • 253 Answers
It is an intergrated circuit chip, Im not sure if it just plugs in, or has to be soldered, this would determine whether you can do it yourself, if you can solder or not
Posted on Jun 15, 2009
  • Gomez Jun 15, 2009
    it is an intergrated circuit chip, Im not sure if it just plugs in, or has to be soldered, this would determine whether you can do it yourself, if you can solder or not
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Panasonic tv turned off, red light blinking and now when I turn it on I now have a portion of the screen from top to bottom with a thick black line with no picture
Wow! EXACT same problem I'm having...4 days later! Did you buy your's about a year ago like I did? Coincedence it breaks after 1 year?! AirForceGeo (in Waldorf, MD)
Feb 17, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
I bought my plasma tv over 1 year ago but only set
it's a defect. we call it red blinking death. the boards inside the tv has gone bad.
Oct 17, 2009 | Panasonic TH-50PX75U Plasma HDTV
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Mar 12, 2009 | Panasonic Televison & Video
My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Need help
Sounds like the convergence amp ICs need to be replaced. This is a common and easy repair. You need two STK392-110. You can get replacement ICs at the following link and they include free installation instructions with pictures and also free instant messageing with their repair tech on line while you do the repair.
Here's the link
Apr 15, 2008 | Televison & Video
TV Won't Turn On
Are you from US or Canada? I'm Panasonic authorized and allways Pana covered the warranty after 1 month from the expire date. Call Panasonic Viera service and tell them the story. I'm sure you'll get refound.
Anyway, a horizontal line doesn't mean the PDP is defective. It's one scan IC burned on the SU or SD board (depend where the line is). We allways replaced the SC bord each time SU or SD got burned. If after SD and SC replacement it still defective...yes the PDP has one scan line in short.
Call Viera and insist to get warranty. Let me know. Good luck!
Jan 30, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
