Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Bag full indication comes on; changed bag; still wont run.
After changing the bag, the full bag light stays on. I can start the vacuum, but it only runs a few seconds then shuts off. If I open the vac, remove the bag and hold the little button (next to the lip of the bag) in, the motor starts and will continue running. Please help ?! My carpet is getting bad!
  • Anonymous Mar 18, 2014
    I changed the bags and it say cheek the bag and isnt vaccuum
    I changed the bags and it say cheek the bag and isnt vaccuum it is kenmoore 11630612003c
  • 73 Answers
Turn the knob on the top of the vacuum all the way to the right and try it again
Posted on Aug 27, 2009
Bag light wont turn off
Hi there! The vacuum may be still sensing dirt in the cleaner. Try wiping the area down in and around the bag port. Be sure you are replacing the bag with a genuine Hoover Type Q bag. Also, when assembling the bag remember to slide the red bag door lock to the right to lock it on. If the check bag indicator light still comes on there may be an issue with the sensor on the vacuum. We would recommend taking your vacuum in to a Hoover authorized service center for repair. Hope this helps! Service Center Locator
Sep 13, 2014 | Hoover Platinum Collection Upright Vacuum
Vac light comes on after i changed the bag
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
http://evacuumstore.com/
Apr 14, 2010 | Electrolux Lux 5500 Canister Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux vac shut off for a full bag. After replacing the bag the vac won't start and the bag full light stays on.What should I be looking for to resolve my problem?
If the suggestion that renevacdoc did not work, it is most likely that your valve assembly(full bag control) has gone bad and needs to be replaced. You will have to take your vac to the Aerus/Electrolux dealer/service store for repair.
Joe
Nov 07, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
Sep 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Have the cannister 6500 SP just changed all filters but when I start the vaccum it shuts itself back off and the full bag indicator light comes on?
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Jun 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum shuts off, bag light on, runs fine without hose connected
I'm not sure if I understand your problem completely, but if it is your full bag indicator that is coming on, even with a new bag, it's probably your control valve. These can be replaced by your dealer. When working correctly, the control valve should trigger the off switch when the differential pressure gets too great between the front of the bag housing and the area behind the bag. When it goes bad, it will indicate that you need to change your bag, even when you don't. Good Luck!!
Oct 30, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
620 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
