Question about Bunn BTX-B ThermoFresh 10-Cup Home Thermal Carafe Coffee Brewer, Black
My bunn thermofresh want heat the water.the holding area is full but wont heat
It was making great coffee and now it aint for the money it should be working
woobie dog
  • 1273 Answers
SOURCE: BT-10-B Bunn Thermofresh that will not heat or fill pot
Lots of times minerals clooect on the heating element and inside the heating chamber. The easiest thing to try is to put white vinegar into the filler, displacing some of the water into the pot. Leave this to soak for about an hour, then flush with several pots of water until the vinegar smell cannot be detected in the water. Make sure that the switch on the side is "ON". You may have an indicator light. The switch on the upper front is for the warmer. The reason you only got a partial pot of water is that the reservoir wasn't completely full. Once you have filled it completely, you should fet a full pot out for every full pot in. If all of the above gives you no relief, you may need to test the heating element for voltage and continuity. If it tests 'open', you will need to replace it.
Good luck, --W/D--
Posted on Jul 17, 2009
  • 5 Answers
SOURCE: Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Posted on May 23, 2008
  • 131 Answers
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Posted on Feb 10, 2009
SOURCE: water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
  • 189 Answers
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Posted on May 19, 2010
Why my bunn thermofresh coffee maker makes cold coffee
time for a replacement . they do not sell heating elements
Oct 31, 2016 | Bunn Coffee Makers & Espresso Machines
Water leaking from my Bunn ThermoFresh
if it is under warranty contact bunn directly , if not throw it away . they are not fixable
Feb 12, 2014 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Unit leaks water from the rear
There is a recall on certain makes of pots for the gaskets. They have a pot repair program that costs money, or you can request the parts from the company they will send you the parts and instructions on how to replace defective part if your pot is part of the recall.
Nov 03, 2012 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
Repairing Bunn BTX-B - Popping the GFI Breaker
the screws are under the flip lid where you ad water. sounds like your heating element is shorted most common problem with the bunn not hard to replace call bunn for replacement or order on line. hope this helps you. .lee
Jan 31, 2012 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My Bunn Thermofresh leaks near the top. In the side nd in the back.
If you will call Customer Service with the model and code date on the bottom. If your machine is 3 years old or less, we will replace it free of charge.
Sep 22, 2010 | Bunn BTX-B ThermoFresh 10-Cup Home Thermal...
My bunn thermofresh coffee pot will no longer keep the coffee hot. I always put hot water in the pot for up to five minutes to heat it up. This still doesnt help.
Is the coffee coming out hot enough? If you measure the coffee as it comes into the carafe, it should register at 175-185 degrees. If it doesn't, then it is a problem with the machine and needs to be replaced. If it is that temperature, then the carafe needs to be replaced. Please contact customer service with the model and date code located on the bottom of the machine. If the machine is 3 years or less it can be replaced at no cost. If over 3 years, it can be replaced at a reduced cost.
Nov 29, 2009 | Bunn B10 Coffee Maker
Good luck, --W/D--
Jul 17, 2009 | Bunn B10 Coffee Maker
Water wont come out of my bunn coffee maker
Jun 02, 2009 | Bunn GR10 Coffee Maker
BUNN VPR
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
Jul 19, 2008 | Bunn Pour-O-Matic VPR
Coffee Makers & Espresso Machines Logo
154 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
