Question about Pride Victory 4 Wheel Mid-Size Electric Scooter
What year is my pride victory scooter - Pride Victory 4 Wheel Mid-Size Electric Scooter
  • Pride Master
  • 1,263 Answers
Hi , i suggest you call Pride and give them the serial number ...
What's your location and i get you a phone number...
Regards
Rob.
www.facebook.com/gewizrepairs
Posted on May 24, 2014
  • 118 Answers
SOURCE: Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Posted on Nov 27, 2008
  • 118 Answers
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
Pride Victory XL-4 Mobility Scooter
You can get then from Prides website
Apr 27, 2017 | Pride Health & Beauty
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
Where do you find the model or year on a Victory scooter
hi, they cover a span of five years, what do you need to know ? or require , the later ones did not have a inbuilt charger...
Regards
gewizrepairs.co.uk
Dec 15, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Jun 03, 2014 | Pride New Mobility Victory XL 4 Wheel...
Year of manufacture
If it is an SC1700, the year is 2008. I will verify for sure if I can find located on the scooter somewhere.
Apr 02, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
Pride Victory scooter repair manual
Piggies might fly = Pride don't want you to go anywhere near one.
Apr 10, 2013 | Pride Mobility Victory 3 Wheel Electric...
Could you please tell me where i will get forward& reverse throttle for pride victory
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Nov 07, 2010 | Pride New Mobility Victory XL 4 Wheel...
Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
142 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
