Question about Acer Aspire One D255 Netbook
I have a new battery and my computer still wont come on unless it is plugged in
I was told my battery may need to be calibrated
Engine turns over but wont start, getting gas, new distributor cap and button. what could it be?
it needs recalibrated,any time you put a new ignition module in a fuel injected ignition Engine,You Will Get Erratic Results.When Your Done,Do Not Take The Battery Out For More Than 15 Seconds Or You Will Loose Calibration
Jun 11, 2014 | 1992 Toyota Tercel
My ibm wont turn on unless the charger is in it just wont turn on.
The battery must have gone bad! if its three or more years old you need to get a new battery for the computer. Periodic conditioning of the battery from first use may prolong the battery life. Battery life is reduced by plugging computer with battery all the time.
Conditioning. Periodic full charge and full discharge practice is good for battery. Batteries are better charged when they are at less than 10% power and its better to charge them to 100%. Do not leave on electric power once they are fully charged.
I hope this helps in future but current battery may need replacement!
Sep 14, 2011 | IBM ThinkPad T40 2373 Notebook
I own a systemax notebook computer that I bought from TV infomercial/QVC. Even though I've been told it's a dinasaur, and slow as a turtle, it still serves my perposes. I do need a new battery as I have't...
Due to the hardware inside the computer its going to be more clearing space on the hard-drive to improve speed very slightly. Here is some good free software, https://www.piriform.com/ccleaner
and here is a site you can get the battery, http://www.wwww.batteryweb.com/notebookdetail.cfm?model=Pursuit%20SV%20%28N34AS1%29&Manufacturer=SYSTEMAX
Jul 04, 2017 | Microsoft Computers & Internet
Car turns over but does not start. Battery good
If it over heated, could have bad head gasket's, fill radiator with water, crank engine with radiator cap off, if water is push out of radiator while cranking, bad head gaskets', also remove spark plug's, crank engine if any water, bad head gasket, also when spark plug's removed, check for any water on them.If there is any water on plug's, bad head gasket, also could try doing a cylinder compression test, if bad compression, head gasket, no compression, wont start that way.
Aug 30, 2010 | 1990 Ford Thunderbird
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
My mom put my ipod nano 4th generation in the washing machine, and now the ipod wont turn on unless its plug to the computer or the power cable
It sounds like your battery is dead.. Your lucky it still even works..
You will need to purchase a new battery
here is a link to a website where you can purchase a 4g battery for 15 dollars.
http://store.kokopellimusic.us//SearchResults.asp?Search=battery+kit
Nov 02, 2009 | Audio Players & Recorders
Laptop wont charge at all, or turn on
hey friend . .
this indicates that your battery is finished just go and buy new or
the battery need a repair . . . its charged is over . .
Oct 06, 2009 | Computers & Internet
Calibrating wont work.. i want to reset it.ive cleaned the screen n taken out the battery...help!!!!
You need a new Touchscreen. FAIRLY EASILY to replace.
http://site.powergamingparts.com/RepairNdsl.html
May 27, 2009 | Nintendo DS Lite Console
Wont charge
It could be that your battery is defective/worn out. If the computer just shuts off immediately (doesnt try to hibernate/standby) then you're likely looking at replacing the battery. They can suddenly do things like this if a cell shorts out in the battery or due to common wear. But first, here are a couple of things you can try.
1. Try reseating the battery (pull it out and put it back in). Sometimes something that simple can fix the problem.
2. Try to calibrate the battery. Your computer may come with instructions on how to do this, but if not you can do it manually. Turn the computer on but go into BIOS (press F10 at the compaq logo screen). Don't load your operating system
Unplug your computer. If it turns off at this point, your battery is already toasted. Replace it.
If the computer keeps running, let it go until it finally shuts off due to battery drain. Then plug it back in and let it recharge completely. This will let the microchip in the battery learn its charge potential and may allow you to get more life out of it.
Note: Calibrating these batteries is good practice but it shouldn't be done very often. If your calibration doesn't work after 1 or 2 tries, you probably still are looking at a dead battery.
Apr 23, 2008 | Compaq Presario R3000 Notebook
Acer Aspire One D255 Netbook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
