Question about GE Adora DSL26DHWSS Stainless Steel
GE REFRIG DSL26DHWASS REFRIG SIDE SEEMS TO HAVE FROZEN UP AND QUIT COOLING, THE FREEZER SIDE WORKS FINE,,,WHY IS THE REFRIG SIDE FREEZING UP???
  • 1122 Answers
SOURCE: Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Posted on Nov 13, 2008
  • 42 Answers
SOURCE: Side by side refrig/freezer not cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 29, 2009
  • 36 Answers
SOURCE: freezer stays cold but refrig does not
Hi there .... check if the fan that circulates the air from the freezer section to the refrigerator section is working or if it is ,is it spinning fast enough to throw the air across .....
Posted on May 23, 2009
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
SOURCE: FREEZER NOT FREEZING
my freezer stop cooling and the other side of refrig is not cooling either model #ed5ftgxkqo1
Posted on Sep 23, 2009
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
GE Profile CF24W-PL
Its simple really,, Your refrigator needs re gassing,, call a professional and he will regas it.
When the gas is running low the fridge cools less and less and eventually will not cool at all when the gas is depleated. Its a natural process and any aircondition or refrigation professional should be able to come to your house and gas up the refrigator , a process that takes a few minutes.. I dont recommend you attempt to do it your self, as it will not take a whole can of gas and if by chance you use the wrong type you will spiol the compressor
cheers
Jan 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge not cooling...freezer works fine.?
Have you checked the damper at the top left hand side, could be frozen - take it off thaw it out and replace. The freezing could have damaged the unit though.
Jul 19, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Adora DSL26DHWSS Stainless Steel Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
