Question about Dewalt dcb100 12v max 40 minute charger
Charger not charging
What more details do you want? The charger WILL NOT CHARGE, NO CHARGE LIGHT. DEAD.
My new Dyson Serial Number PM8-US-HHB1494A will not charge.
Suspect a dead battery or a defective charger
Dec 28, 2016 | Dyson Vacuums
Only the red light comes on jazzy select charger
Batteries must be stored on a full charge. For extended periods they should be disconnected. If your batteries are flat/dead the charger will not attempt to charge them. You should remove your batteries and check and try to charge them individually. Sometimes they will come alive, must of the time they won't. Charge them individually with a 12 volt 2 amp charger - no higher; or in series with a 24 volt 4 amp charger.
Mar 01, 2013 | Health & Beauty
How to charge a psp with usb cable while it's dead
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
May 24, 2012 | Sony PlayStation Portable (PSP) Console
It is not chargeing nor turning on
Some of these chargers are automatic to the point of aggravation. They will only operate when they are connected to a battery with at least a small residual charge. Not sure if this charger is one of those. Try hooking it up to a known good battery. It that works, and you are trying to charge a dead battery, first use jumper cables from a good battery to the dead one for a few minutes. Then hookup your charger to the dead battery. That should give it enough charge to prime the charger into working, and you could then remove the jumper cables.---- but be careful!!! wear safety goggles.
Jun 20, 2010 | Schumacher & Fast Charge Starter Charger
The camera doesn't open and it doesn't charge. It is dead.
I wonder if you attached the right voltage of charger.
Thats what I did. I put on a 9v dc charger
Now my v570 is dead......but ironically it will still charge a battery.
Now an expensive battery charger!
Sep 13, 2009 | Kodak EasyShare V570 Digital Camera
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Lights on charger do not light and therfore do not charge roomba.
If the charger doesn't light up, it's broken.
Call customer support at 1-877-855-8593. Be sure to have the Roomba and charger with you when you call-- you'll need them.
May 28, 2009 | Roomba Robotic Floor Bagless Vacuum
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Dewalt dcb100 12v max 40 minute charger Logo
99 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
ka4iup
ka4iup
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
