Question about Jeep 2006 - Grand Cherokee 4X4
Clean fan cage on 2006 jeep grand cherokee
Clean debris from heater fan
  • 4 Answers
SOURCE: Heat/AC Blower fan speed only works on High
Alot of people have the same problem with the fan switch and blown bulbs. There really is no fix for this. Jeep really screwed up when designing the heater control assembly. The cheapest solution is to buy another unit off Ebay. Can always go to the dealer but be ready to PAY for there mistakes.
Posted on Jan 21, 2009
inhisname
  • 76 Answers
hello, this sounds like a bad blower motor resistor!! its cheap and easy to change..if you need more info on locations let me know,, good luck.....marty
Posted on May 27, 2009
SOURCE: 2006 Jeep Grand Cherokee Laredo ac not cooling
My 1999 limited does this. When i bought it off the guy he said that its because of some flap down by the passengers left foot. In mine the passenger air barely even blows because of this.
Posted on Jun 20, 2009
  • 90 Answers
SOURCE: HOW TO REMOVE HEADLIGHT ASSEMBLY 2006 JEEP GRAND CHEROKEE
remove the 7mm bolt in the centre top of lamp unit then with a big screwdriver just behind headlamp prise outwards quite firmly
Posted on Jul 03, 2009
  • 5 Answers
SOURCE: 2002 jeep grand cherokee fan not working?????
Replace the fan relay switch. The dealer will charge you 400 to pull the bumper off, or you can buy the part for 45 and cut the hole in the plastic near the passenger headlight assembly and replace it yourself. There are instructions for this procedure on the web somewhere. I have had this problem more than once with my 02 GC V6.
Posted on Aug 10, 2009
Blower fan is hitting something . Do I need to remove battery cable to work on this?
no you don`t need to disconnect the battery to work on the blower motor.just remove the motor and check the condition of the squirrel cage(not damaged) and check inside the air box for debris and clean out.make sure the noise is not the blower motor itself.
Jul 06, 2011 | 2006 Jeep Grand Cherokee
My fan won't blow hot or cold air unless i'm driving fast on the interstate
Sounds like your heater blower motor is not functioning properly. At high speeds it's probably drawing air in from the outside then through the vents (defrost, etc.). If blower motor sounds like it's running, then maybe the squirrel cage (heater fan blade) is not spinning and in need of repair or replacement.
Dec 09, 2010 | 2002 Jeep Grand Cherokee
Blower fan to a/c on 2006 jeep grand cherokee laredo is making noise when turned on. what could be the prob and what needs done to fix? where can i get schematics for it?
You won't need a schematic, you just need to remove the blower motor and check that the fan cage is not cracked or broken, if the fan cage is in good shape then its your blower motor that needs replaced.
It's and easy and cheap fix, and you can get both parts if need be from your local parts store.
Aug 01, 2010 | 2006 Jeep Grand Cherokee
There is a noise that my heater makes when the heat is on. The heat still works, but as you turn it up higher , the noise gets louder. What could be causing this?
Probably some leaves or debris in fan cage. remove fan and clean. or it could be a bad fan motor bearing remove and replace.
Apr 20, 2010 | 2001 Jeep Grand Cherokee
How to replace 2006 Jeep Grand Cherokee fan Heater Blower Motor
the blower motor is under panel near glove box. remove connector then the 3 mounting screws that hold it in. if changing the motor, use old fan cage from blower to new one, remove retainer clip to take off of motor shaft. CARL,
Dec 17, 2009 | 2005 Jeep Grand Cherokee
2006 Jeep Grand Cherokee 3.7 is overheating. Mainly at stand still and slow traffic. Once it hits High it pushes back down to normal level within one or two minutes and repeats. coolant levels are good...
sounds like you have a partially obstructed radiator (either bugs or other debris packed into the ac condenser, leaves between the condenser and radiator or an internal blockage inside the radiator core.) if it is not external it can possibly be cleared by flushing, though most flushes available today are fairly weak and tend to go around obstructions instead of going through them. if flushing does not help, replace the radiator.
Oct 21, 2009 | 2006 Jeep Grand Cherokee
The blower fan on 1997 Jeep Grand Cherokee squeeks when running.
Maybe that's why they call it a squirrel cage. Seriously, noise is either from something caught in the fan or a bearing in the motor is dry and beginning to fail (motor needs replacement) Either way you need to remove motor to check it.
May 11, 2009 | 1999 Jeep Grand Cherokee
1998 Jeep grand cherokee inline 6
Check the blower motor under the dash.(on right side put a 12v lead directly to the connection and if it works, the problem may be in the switch relay or resistor pack. (i've also heard of debris holding the fan from moving so if there is power there and motor does not run, remove & check first before buying a new unit.)
Apr 06, 2009 | 1999 Jeep Grand Cherokee
A/c heater fan no blow
sounds to me like the blower motor resistor, and if I'm not mistaken the resistor and the blower motor are located under the dash on the passengers side. the resistor should have a wiring connection and 2 screws attaching it to the blower case. The a/c and heater blower will not work if the resistor goes out. hope this helps you out a little. Best wishes.
Jan 16, 2009 | 2006 Jeep Grand Cherokee
Jeep 2006 - Grand Cherokee 4X4 Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
