Question about Samsung Brightside
Touchscreen is not working
Very suddenly my touchscreen quit responding to touch
SOURCE: Samsun pixon touchscreen appears frozen
it's a problem with the connection between the touchscreen and phone. the m880 is notorious for it. there's a few quick fixes but they don't last long. take it in to get fixed or buy a different phone, mine is six months old, same problem.
Posted on Jan 27, 2010
  • 2069 Answers
SOURCE: touchscreen not working
do a hard reset first; when your phone is on, pop out the battery, and put it back again and start phone. check if problem is fixed. If not fixed, use this code *2767*3588#, note that this may erase all your data so if you can backup, then do. If problem still there, then it is hardware. take unit for servicing. you may have to replace either the touch screen or flex cable buts needs to open unit first and confirm.9look out for water damage e.t.c)
Regards
Posted on Feb 02, 2010
  • 11 Answers
SOURCE: touchscreen on samsung
the same thing happened to my phone. my first impression (that i only had for 3 1/2 months) decided to completely freeze the touchscreen, when i had absolutely no water damage and had never dropped it. i tried EVERYTHING took out the battery and the sim for an entire day, turned it on and off, and nothing worked. One thing i know, try your best not to drop this phone because my friend also had to get a new one because she dropped it several times, and they are VERY sensitive, and dropping it throws off the calibration, as does getting liquid on the screen. I went to a local at&t store and they said I would be eligible for a new phone because I had not caused the phone to stop working, but they could not give me one at the local store. i went to a DSC (device service center) for at&t, and the guy took one look at my phone, tried to play around with it, and within a couple minutes said I would be receiving a new phone that day. I received a new phone, and even got my numbers and my sim transferred for me. if your phone continues to freeze up, definitely bring it in. hope this helps :)
Posted on Feb 28, 2010
SOURCE: The touchscreen won't respond when i touch it
Take the back cover off at the top you will see two screws remove them and you should be able to pull away the front cover useing your finger nail where the volume controle is then try the screen again it should work its a bad contact on the screen ribbon. If it works click it back and try again this worked on my phone put the screws back in hope it works for you.
Posted on Jul 11, 2010
danishkurar
  • 164 Answers
Posted on Jul 24, 2010
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
Touchscreen does not respond to touch .
CHECK THE FLEX OF UR TOUCHSCREEN IF ITS BROKEN;IF NOT JUST LIFT THE SOCKET AND PLACE IT AGAIN.
Jul 27, 2012 | Handspring PalmOne palm treo 600 Silicone...
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
My buttons on my phone works but my touch screen is not responding to anything at all.
check MENU settings may be touchscreen is off ,else touchscreen loop is broken
Aug 02, 2010 | Cell Phones
Fujitsu p1120 touchscreen not working
Before you open up your computer, try downloading the touchscreen drivers from Fujitsu's website and re-installing them. Sometimes they just get flaky.
Mar 19, 2008 | Fujitsu LifeBook P1120 Tablet PC
Nintendo DS touchscreen problem
try calibrating the touchscreen....
Jan 08, 2008 | Nintendo DS Console
Touchscreen doesnt respond
Hi Your touch screen is part of your LCD and it was connected together thru a small thin cable and it is fragile. When this cable is bad or lost contact , your touch screen is disabled. Only way is to open the case and replace. The method to replace it was tricky. If you make a mistake, you can damage your LCD or scratch it. Please visit these sites for some information: 1) http://www.pocketpcman.com/index.html 2) http://stores.ebay.com/ElecRealm (Store sell Touch Screen) 3) http://www.pdaparts.com/ I hope these information will help you to find the solution for your MDA. Actually, I am repaired all phones and PDA too. If yo need for my help, you can email me at joe_dao2003@yahoo.com. I am writing a lot instruction of how to repair or replace the housing and LCD/touchscreen or can be called digitizer. Good Luck. Regards, Joseph
Apr 30, 2007 | T-Mobile MDA
Samsung Brightside Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
