Question about Sony Televison & Video
I have the same problem with closed captioning. it won't go away
I have a sony, but have to use the remote that comes with the Time Warner DVR. I've tried turning off the cable box and just using the menu on the TV screen, but there's no way I can get the selection to move over to the right to the closed captioning part of the menu. We had a major storm and the power went out and now we have closed captioning. Any way to get rid of this?????
TTM77
  • 19 Answers
SOURCE: Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Posted on Aug 26, 2006
Noggin
  • 944 Answers
SOURCE: Closed Caption on all time, sound is not muted
Here is the link to the user manual for your tv if you need it; http://www.p4c.philips.com/na4/2/20ms233s/20ms233s_dfu_aen.pdf page 19 suggests press status/exit on the original remote should do it, if not then see if you can find anything else in the manual. Hope this helps, please post again if not :)
Posted on Mar 20, 2007
circuitcity
  • 137 Answers
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Posted on Dec 09, 2007
circuitcity
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How do i add channels on my tv
The closed caption just suddenly appeared on my screen with no buttons pressed. It won't turn off. I no longer have the original remote for this Durabrand 13" DU1301 TV . I was using the Time Warner Cable remote and have a basic cable box attached to the TV. Everything was fine until suddenly with no buttons pushed the closed caption came on. Is there anything sort of buying a new tv to fix this
Sep 11, 2011 | Durabrand DU1301 TV
I can not remove closed captioning on all my channels. i use time warner cable remote control. i dont know how captioning came about. pls help. thanks
As best I can tell, the TWC remote requires about 12 steps to turn CC on & off - very annoying and I can't understand why it's not simpler. Hit the blue menu button near the top; scroll down or up to Settings, hit enter, scroll down or up to Captioning, hit enter, scroll to how you want CC (off, on, or just when Mute), hit enter, then hit Exit to clear the screen. A pain, no?
Jul 02, 2009 | Sharp Remote Control
Close captioning stays on all the time.
if have remote or tv bo to menu scann threw it find captions and set off this may help
Mar 24, 2009 | Mitsubishi WS-55807 TV
Time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
Nov 10, 2008 | Toshiba 36A50 36" TV
Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Jul 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Need set up code for my universal remote
Mail me also chainlu@yahoo.com
May 18, 2008 | Televison & Video
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
