Question about Wolf Designs 270702 Heritage Module 2.1 Six Watch Winder With Cover
Operating instructions wolf watch winder
How to operate unit
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
Pull the winder knob out then push it back in ever so lightly you will feel it click then wind it fwd till you have correct date and other way should give you the day if its one that first needs to be wound backwards before you can pull it out then make shore you rewind it back till it stops or it wont be water tight
Dec 26, 2013 | Seiko SNXS73 Wrist Watch
The second hand is not moving even when i wind it
This watch is an automatic type and may you not be able to wind it up use the crown wheel (winder). The details on their web site do not describe the operation of the watch, so I can't be absolutely sure about this.
You can wind an automatic watch by swinging it genetly from side to side for few minutes.
When fully wound, the watch will remain working for 42 hours (when not being worn).
These watches thrive on being used and if used daily, they should remain operating.
Dec 24, 2010 | Christian Dior Dior Chiffre Rouge...
I have a new, purchased ar an auction so no paperwork a Cartier pasha woman's wristwatch. I don't know how to wind it. Please tell me
There are several models of this watch and you don't say which one you have but thi range are either automatic (which means that it is self winding) or quartz (battery driven).
If it is not going it could be
(1) (for a quartz watch) the winder has been pulled out (push it back in) or the battery has expired. (Do you know how old the watch is?).
(2) If the watch says "automatic" on the face, then it haas probably just run down (they run for 2-3 days if they are not used). If this is the case, holding the watch horizontally, swing it gently from side it side for a few minutes (this will operate the self winding mechanism) and the watch should then start. To keep an autimatic watch operating it needs to be worn daily or placed on a winder when not in use.
Aug 23, 2010 | Watches
I have just purchased a guess w12575 ladies watch but am unable to alter the time on it as the winder won't open. i had no instructions in the box when it arrived to help me. I have tried pulling the...
Some winders need to be unscrewed (its a water resistance feature).
Try turning the winder anticlockwise about a quarter of a turn or so.
(Don't forget to screw it back in when you have finished!)
Mar 23, 2010 | Guess Sport Leather Strap W12575L1 WW...
How do i set the time on my luminox 8100
I was unable to find any instructions on the Luminox web site but I suggest you try the following:
Screw the winder anticlockwise ( to release it) and the pull the winder out. I would expect to find two "out" positions, one for the time and one for the date setting.
After setting the watch push the winder home and screw it back in.
Jan 17, 2010 | Watches
Just want to ask about my new tag heuer watch???
Yes. it's normal to hear that soft noise when winding manually as all the gears gets engaged.
I would recommend watch rotator (winder) by Wolf Designs, Module 1.7, but you can choose for yourself.
Here is a link to Wolf Designs:
http://www.wolfdesigns.com/?a=getp&oid=215&cid=3&scid=11
Don'y forget to rate, please.
Nov 02, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Rolex submariner
Rolex's are wound by your movement. Try moving your arm back and forth and see if that helps. Also make sure that the crown is screwed in securely. If it's not a watch that you're not going to wear all of the time, you might want to buy a winder. I've bought several off of Ebay for around 30 dollars. They simply display and spin the watch off and on keeping it running. Good luck!!
Jun 06, 2008 | Rolex Daytona 116520 Wrist Watch
Wolf Designs 270702 Heritage Module 2.1 Six Watch Winder With Cover Logo
66 people viewed this question
Top Wolf Designs Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Wolf Designs Watch Expert? Answer questions, earn points and help others
