Question about Little Giant Plumbing
Little Giant #506065 WRSC-6 1/3 hp
Pump not coming on
5 Suggested Answers
  • 19 Answers
SOURCE: hello, my little giant dinosaur pump stopped
No reset, the pump may have just failed internally, try another plugin to varify power, if no joy than look at a new pump
Posted on May 18, 2010
  • 19 Answers
SOURCE: 10 Cia, 1/2 Hp, 83 Gpm Automatic Submersible Sump Pump 10' Power Cord : my little giant punp 10-cia has water in the main ...
Nope, not a good thing
SOURCE: Little Giant Condensate VCMA-15UL pump. Pumping when the float was down.
new pump
Posted on Nov 12, 2012
  • 371 Answers
SOURCE: I don't have anything in the vent hole it has threads do I need something in there? It is the little giant model wrsc-6
The vent pipe must be vented to an open air pipe.
Posted on May 03, 2015
Little Giant 506065 - 2 did not work after 21 days, different pump better?
Are you running these pumps full-time, even if they're dry? If you are, that's far beyond their design. The sink should drain into a sump or cistern, then the pump should empty the cistern on demand from a float switch.
I don't know of any pump except possibly a bellows-type bilge pump, that can be expected to run full-time, even when dry.
Aug 13, 2014 | Little Giant Plumbing
Little giant WRSC-6 won't shut off
The vent should definitely be connected to a vent pipe. (Does waste water rise in vent pipe, or can it outgas to indoors? If the latter, maybe it would work not connected.) Mine just quit after 17 years; it would come on and not shut off. I figure it was either the switch assembly stuck on, a blocked output, or a failed pump. I pulled it all apart and found that an O-ring in the pump housing was hanging out of the seam. Owners manual warns against taking apart anything in the pump housing, and given its repulsive appearance, I ordered a replacement pump ( about $125.) I was a little irritated at the original plumbers' installation. With all the PVC pipe glued into place, it was unserviceable without cutting all the pipes and replumbing. I'm installing 1 1/2" unions at the three ports, and the next time, it will be removable for inspection, etc. Got top and bottom halves scrubbed out and ready for a midnight trip through dishwasher. So, if yours used to work, either the switch is falsely telling the pump to keep going (switch replacement kits are available), the pump is not moving the water (as in my case), or the pump is trying really hard and maybe a check valve isn't opening to let water out.
Apr 16, 2013 | Little Giant Wastewater Removal Sys -...
My drainosaur 506065 pump chugs on and off for hours and does not empty sink. I pulled the plug. I think it's clogged with debris. Can I clean filter and discharge line myself? How?
Before cutting pipes apart...remove the pump and check the intake part of the pump...
Often the intake holes will plug with debris and all you have to do is clean that....
Also make sure that the check valve is closing... often that will get debris in it an allow the water to just run back into the pump...
heatman101
Feb 19, 2011 | Little Giant 506065 Wrsc6 506065 Drnosaur...
Active Pump Will not shut off.
shutoff float/switch is stuck.. replace the pump.
Nov 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Won't shut off
the auto shutoff has failed, either because its dirty and needs to be cleaned or it may actually be faulty. Clean or replace the auto shutoff mechanism.
Nov 07, 2009 | Little Giant 506065 Wrsc6 506065 Drnosaur...
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Sump pump
The big cylindrical thing at the end of the wire hanging is the switch. I believe it is a mercury switch. Try hitting this a little and see if it stops. Sometimes they get stuck. If this doesn't help, then replace that piece. Hope this helps.
Jul 06, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Plumbing Logo
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
