Question about Magic Chef Kitchen Ranges
Ge profile model # jb960wy1ww the smooth top will not heat up and nothing else works unless burner is turned on HELP?
Cant get smooth top to heat up
  • 58 Answers
SOURCE: GE Spectra Profile - dual burner only has one temperature - HIGH!
you need a new switch that is in the control panel
Posted on Mar 12, 2008
SOURCE: cleaning and care for my GE Profile stovetop
The one thing I don't suggest is using the Ceramabryte product the dealer left with us. It leaves a greasy film. When I get ready to clean my black GE Profile, I pull off the controls to wash separately. Then I lift off the grates, take a single-edge razor blade to scrape anything stuck on (it doesn't scratch), then I use baking soda and scrub and scrub with lots of paper towels. Then I start cleaning off the baking soda with lots and lots more paper towels. There is still a film, but at least it's not greasy. At this point I grab some more dry paper towels, pour on a 3' puddle of rubbing alcohol and wipe it all over the stove top and front. You may have to do this twice. Then, if I don't turn on the hood light's brightest setting, it really doesn't look too bad. I have to do this at least once a week, as I have never had a stove that got so dirty so fast and was such a pain to clean.
FYI, I would never buy another of these stoves. Besides the cleaning issue, there is the fact of having to replace the igniter (glow plug?) twice in the first four years. My old, bottom-of-the line Magic Chef went 25 years with the first replacement not coming until it was about 15 years old. Also, the broiler is unimpressive and steaks, etc., just sort of steam. Can't get a really good crust going. It's a slide-in and the top is very narrow, front to back, because of the slanted control panel on the front, and so you really can't put two large pots or pans on one side. Let's see....oh yes, I ordered the unglazed grates for safety reasons and it came with the procelain glaze. Those were replaced free of charge, though I had to go pick them up. Then the first set of unglazed grates began to rust about six months into use, so had to be replaced (again, no charge at least). Recently I noticed that the inside walls of the oven, where the racks slide, are starting to rust. Finally, the burners are difficult to calibrate, which I really notice when I try to cook rice, which comes out right about 50% of the time.
Now, on top of all this, I have to worry about the glass door exploding?!?! Should I ban my grandchildren from the kitchen? Has anyone from Consumer Reports seen this website?
Posted on Apr 03, 2008
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
IrishDruid
  • 2712 Answers
SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
SOURCE: JBP84TOHWW GE Electric Range Large Dual Element Not Working
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
Posted on Apr 11, 2010
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a ge profile that is 13 years old. the burners work but the oven will not heat, I checked the breaker and turned it off and back on to reset oven but it still does nothing. any thing i might try,...
Greetings,
If you look carefully at the bake element..There may be a burnt spot or not smooth to the touch..If it has any bumps or blemishes...Its bad. If you have an ohm meter you can check the bake element for continuity...if none, its defective......in most cases its the element that goes bad...
If you do have a volt/ohm meter you can check for voltage and I've even seen the wire burn off where it connects to the burner itself...The thing to really be sure of is power going to bake..if not power, its either the board relay keeping it off or a wiring problem...ie burnt wires
Bruce Denton
Dec 12, 2010 | GE Profile JTP18 Electric Single Oven
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Jan 24, 2010 | Kenmore Kitchen Ranges
Burner seems to be wired backwards
You have to access the underside of the cook top. Does the back right work correctly? If so switch the wires on the back left to match the right burner.
Jul 01, 2009 | Kitchen Ranges
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
Kitchen Ranges Logo
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
