Question about Refrigerators
Indesit fridge keeps running
Indesit fridge/freezer keeps running
    President:
  • 1,185 Answers
Either the motor relay is stuck in the on position or you need a new thermostat.
The thermost control can be withdrawn from the casing inside the liner , if you do so then take the power off before you try.
There is normally only one screw holding the stat in position and the unit will pull out far enough to allow you to remove one of the leads attached to it.
Make sure that the lead is taped over and then switch the freezer back on again
The motor should not run, if it does it is not the stat and you will need to check out the compressor motor relay for burning.
If you are not sure then ring for someone to come out who is qualified
Posted on Jun 15, 2009
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Why freezer not working on indesit fridge freezer
is your fridge working or is the compressor running.
May 27, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge/freezer starting & stoping
The compressor is supposed to start & stop, it wont run all the time.
Nov 22, 2013 | Amana ABB1927DE Bottom Freezer...
Fridge is running but won't get cold
if it have one compressor the gas in the system are low . but if it have 2 compressors the thermostat can be the problem
Jun 01, 2009 | Refrigerators
My indesit freezer in on amber light on 1 and it is too cold should the light be showing amber
check to see if you dont have unit on quickfreeze.or possibly the thstat is set to high or control is faulty
Jan 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer.
lower the number, warmer the fridge.
setting 1 - warmest
setting 5 - coldest
this is the same for all fridges
Jun 29, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
