Question about Sanyo DRW-500 DVD Recorder
Has trouble recognizing a new blank DVD
Have had unit for 5 years and it has worked great, lately, however, it has had problems recognizing a new blank dvd, I have to load it 2-3 times before the machine will accept it??
  • 253 Answers
Try a cleaning disk, if that doesn't help, goto the manufacturers site and check for a firmware update in the support and drivers section
Posted on Jun 15, 2009
The unit acts as though it is not receiving power. I have verified that it is receiving power, I have unplugged it as the manual directs and have waited SEVERAL minutes before replugging in and pressing...
hi,
now a days we can't sourly say that, the new electronic equipments will work for along time. you have mentioned that ur dvd player has no problem for the last 3 years. its very good.
from ur narration i think ur dvd players power supply have some problem. may it will the only problem. just try to service it. may work for the comming three years.
ok
Dec 17, 2010 | Philips HTS3544/37 Theater System
Doesn't recognize disks anymore
i would try lens cleaning cd 1st ok might be dirty lens just cant read it if not that try firmware update to the unit thx nick
Feb 04, 2008 | Lite On LVW-5005 DVD Recorder
My dvd drive has started acting up. It no longer recognizes -dvd.
It has been my experience with Lite-On to be a great optical drive replacement. In the 10 years I've been in business, Lite-On has been my top choice for pcs. If you continue to have problems try a different BRAND of blank DVD media.
Good Luck
C2Solutions
Jan 05, 2010 | Dell XPS 410 PC Desktop
No Disc
I had this identical problem just after a year and a half of use. I tried cleaning the lens... that didn't change anything. I tried using movie discs that I knew had worked before.... same problem. I took the unit apart and found the problem. There 5 or 6 (I forgot exactly) capacitors on the power board that are black cylinder types with silver tops. If the tops look like they are bulging, then It requires changing capacitors on the power board. I ordered them through the internet, removed the old and installed the new capacitors. Now everything works great.
The capacitors are: 10v 2200uf 105-Degree Capacitors. They cost about 20 cents a piece.
Good luck.
Nov 12, 2008 | Cyberhome DVR 1600 DVD Recorder
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Dec 29, 2007 | Lite On LVW-5005 DVD Recorder
Sony DVD RW DRU-710A won't burn dvds
sounds exactly like my old dead drive. if it cant boot from a cd its likely a bad drive
Nov 02, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Won't read DVDs
Hi, Ive just repaired several liteon's ( incidently they are identical inside to some philips models ). In most cases the non writing or non reading problem is caused by dust on the laser glass. You have to open the unit then remove the dvd drive then remove its covers and just give a wipe of the laser with a clean non fluffy cloth. If theres lots of dust in other parts of the drive then this will need to be removed also as it could easily get onto the laser when in use. Even almost new liteons can suffer the problem , it only needs a little bit of dust to top the laser shining onto the dvd , instead the dust just reflects the light back. Hope this helps.
Oct 27, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Aspi problems with audio ripper programs
try using the recommended software in your unit.
Nov 19, 2006 | ASUS (90-N801W1000) DVD-RAM/DVD-RW Burner
Sanyo DRW-500 DVD Recorder Logo
150 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
