Question about Kenmore 84152 Electric Dryer
Dryer won't Start
Dryer is 2-1/2/ years old. Two days ago, I did several loads of wash and the dryer worked fine for everything. Yesterday I did a small load of wash, put the clothes in the dryer and pushed the start button... nothing happened.
All the panel lights light up, the knobs and buttons to change settings work, but when the start button is pressed... nothing.
I verified that there is current to the dryer, and reset the circuit breaker for the 220v going to the dryer. All looks fine. Looked in users manual at troubleshooting guide and it said that it could be the "Thermal limiter was tripped" and to call service for replacement.
Called Sears and made appointment to have service man come out next week.
This morning, I decided to push the start button just for the heck of it. The dryer came on !!! I know it's Halloween...Are we possessed, or what???
I let the dryer run for 45 minutes in no heat mode just to see if the motor would "kick out" after heating up or something, but it seemed to work fine.
Any suggestions here?... I'm certain that this will happen again.
  • Frank Kuhlman Nov 01, 2007
    Actually, I checked for that. This is really weird. It has stopped working again on several occassions. I can press the button and nothing happens. I can walk to another room, come back, press the button, and it starts. I've stood in front of it, pressed the button, watched it start, then pressed the pause button. If I do this 10 times, 3 of the ten times the unit will not start. This is really annoying, becaue sometimes when it won't start, I can try it for 5 minutes, and it won't do a thing. But if I come back in 10 minutes, it might start again. I've made sure the door is engages and the door switch is activated, etc.
    I can't figure out what would be so intermiittent as to act like this.
  • BrokenKenmor May 13, 2008
    Have been having the same problem, only it seems to be getting worse with time. The dryer is almost 3 years old...have been having the problem for about 4 months, so I guess it started after 2 1/2 years. The interior light works, the knobs beep and light up as usual when turned; the buttons beep and light up when pressed. BUT, when you press START, it only beeps....the dryer doesn't start. Usually, eventually it will start after trying many, many, many times; but sometimes it is a whole day before it will start. If anyone has a definite solution, I'd love to hear it!
  • 164 Answers
The problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Posted on Nov 01, 2007
  • 291 Answers
Maybe dryer door switch wasnt fully engaged
  • Mike Johnson
    Mike Johnson Nov 01, 2007
    U might check you connections at the dryer and take cap off receptical plug in and check for loose wire or a connection anything thats looks brown or burnt....
    thats all i can think of at this point .. I have had simular situations where it would be a burn side of the cord.. receptical, or even just a little loose or burn... where connection was lost at different times driving me batty...
    hope u can find something.. i know how crazy it seems... makes ya think its got a ghost in it or mind of its own... lol
My Kenmore dryer is about 10 years old. I got my laundry out, put a new one in and .....nothing. No beep no light just silents. I checked the fusebox and the plug and it seems fine. What could be wrong??????
Posted on Jul 08, 2008
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Our 8 year old kenmore dryer won't do anything when you press the start button. We don't hear even a hum. It worked one day and then just wouldn't start the next day. We checked the fuse box...
Here is a good link for basic troubleshooting... But 10 to one the culprit is a thermal fuse or thermal cut off.... they are usually pretty cheap and easy to replace....
One final note on these: if you find your thermal fuse\cut off (or element) open, before replacing it, be sure to check the airflow out your dryer's vent system. Even though these devices do 'wear out' with age, poor airflow's the #1 cause of failure of these devices, and if your vent's partially clogged, a new thermal won't last very long, but will do its job again, and leave you 'cold' (a new element won't last long if the vent's clogged, either).
More info and pics:
Jun 16, 2011 | Kenmore Dryers
I have a Kenmore Elite electric dryer. It is only two years old. The dryer is a HE 3. Model 1108787 or 1108789. It was working fine two days ago then after finishing the dryer load it was on....I went to...
This could be one of several things.
1.thermal fuse is blown(with power off(unplugged)check for continuity)
2.Belt is broken (check belt).
3.loose wire somewhere
4.Door switch malfuntion push in on it and and test for continuity.
5.The control board is malfunctioning.Try removing it and observe the back of it for burnt or cracked places.
6.Motor is bad test for power to motor see wiring diagram and tech sheet inside cabinet.
Input full model # here for parts and diagrams. Model # should be located just inside of door.
Nov 03, 2010 | Dryers
The worked fine 2 days ago then went to use it
Hi there,  I'm not sure if you've had your dryer fixed yet, but it sounds like the heat exhanger (which is located on the lower right front side of your machine. To clean this, you must first disconnect the power cord from the wall. Next, you slowly remove this and clean it thoroughly with running water. After you wash it, let it dry completely - and then insert it back into the machine. It's a good idea to write down the steps you took in removing it, so when you put it back - it will make it easier. If it's not inserted right, your door won't close - so that's why it's important to jot down the steps when you removed it. Hopefully, this has been taken care of already. But if not, feel free to contact me. Also, it's a good practice to change the lint trap before or after each load. This machine is very sensitive to it, which is good - because it's protecting it and its longevity. Good Luck!
Jan 13, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Washer / Dryer will not start at all...
ngfam1 here for you!
I am happy to be of assistance!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Aug 26, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 84152 Electric Dryer Logo
4,420 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
